Old 12-02-2012, 06:40 PM   #1
1972 23' Safari
Camas , Washington
Belly pan questions
I removed the forward belly pan today and under the forward subfloor was a sheet of aluminum between the subfloor and frame. Is that normal? do all subfloors have this piece? I don't recall reading anything about the extra piece of aluminum. here are a couple pictures, lots of wet insulation no insulation under the front piece.
thanks,
David and Pam
ID:	173767   Click image for larger version
Pams72 is offline   Reply With Quote
Old 12-02-2012, 07:01 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
Maybe it's for the option of putting a spare tire holder there?
reinergirl is offline   Reply With Quote
Old 12-03-2012, 09:46 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Yep, that is set up so that if you have the spare tire carrier mounted in that first bay, that the subfloor is protected from splash.
I was afraid of the belly pan Dingo Girl 1966-68 Caravel 26 10-05-2016 03:27 PM
How do I remove the belly pan? aluminitus Belly Pans & Banana Wraps 19 10-21-2014 10:50 AM
Belly Pan replacement canoeman Repairing/Replacing Floor &/or Frame 2 02-10-2012 02:37 PM
1985 31' Excella Belly Pan Questions Eugiepayset Belly Pans & Banana Wraps 3 06-27-2011 12:04 PM
which aluminum sheet for belly pan???? clipperguy Belly Pans & Banana Wraps 2 04-26-2011 05:21 PM
