Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 09-09-2008, 12:57 PM   #1
Zstream
MyFirstStreamer
Zstream's Avatar
Profile:  1963 26' Overlander
Indiana , Indiana
Question Belly Pan paint or sealant?
After spending days sanding and re- riveting my Belly Pan I am wondering if anyone has ever painted on some sort of sealant or protective coating to the pan area? I believe it would be nice to protect from road debris and help with washing off salt and sand etc.... Anyone have a thought on such a procedure and/or product tips? Tks. Z.
A chief event of life is the day in which we have encountered a mind that startled us. -Emerson
Burning Man ~ Black Rock Desert Nevada 2005 & 2006 -Zstream
Zstream is offline   Reply With Quote
Old 09-09-2008, 01:09 PM   #2
purman
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
Is the belly pan Aluminum or stainless steel on airstreams,,, Mine is rusted in the back I wouldn't mind coating it either..
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
'89 Jaguar XJ6
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
purman is online now   Reply With Quote
Old 09-09-2008, 02:42 PM   #3
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
What I did in any pitted or rusted areas on the entire under body is a quick coat of POR-15 about $40 a quart.
A quart goes a long way
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 09-09-2008, 02:56 PM   #4
silverleeper
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
Bed liner
Why can't you use a bed liner? I have given this some though while working on the belly pan. This place here seems to have a good gray HERE. I don't work for this company I'm using it for an example I'm sure other companys can do the same thing. Any thoughts?
Lee
The more I learn the less I know!!
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
silverleeper is offline   Reply With Quote
Old 09-09-2008, 03:06 PM   #5
crispyboy
crispyboy's Avatar
Profile:  1981 22' Excella II
alexandria , Kentucky
When I had the belly pan off of my trailer I took a wire wheel and knocked off the corrosion/etc. Cleaned it up with some thinner and rolled Rustoleum Aluminum paint with a paint roller. Except for a few pitted holes it looked great.
crispyboy is offline   Reply With Quote
Old 09-09-2008, 03:30 PM   #6
LI Pets
Silver Mist
LI Pets's Avatar
First it is heavier than any paint cost more I'll guess and
It must weight more, as such may pull down its own weight and sag the pan.
Spend $40 it will last for years with the por-15
WBCCI
Old 09-09-2008, 04:23 PM   #7
silverleeper
1960 18' "Footer"
Yes it is. But, if you apply a thin coat wide head rivets will take care of the extra weight. I don't suggest putting it on a thick as a bed liner. The cost will be about double and this is a do it yourself project. Por-15 is a great product but is not as flexible or chip resistant as a bed liner.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
Old 09-09-2008, 04:26 PM   #8
LI Pets
Silver Mist
LI Pets's Avatar
I disagree, did you ever try taking it off!
WBCCI
Old 09-09-2008, 04:43 PM   #9
silverleeper
1960 18' "Footer"
Li Pets, Yes I have. I'm simply offering a different view point. Have you tryed anything else besides Por-15?
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
Belly Pan Opinion Please PoconoAir Belly Pans & Banana Wraps 14 05-09-2007 09:11 PM
belly pan aluminum? where? pinkflamingoes Belly Pans & Banana Wraps 33 11-03-2006 09:33 PM
Belly pan--Opinions?!? eljay Belly Pans & Banana Wraps 4 12-28-2004 09:26 AM
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 16 07-18-2004 09:16 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 2 08-30-2002 01:27 PM
