Old 04-25-2015, 07:22 PM   #1
Tino
Tino643's Avatar
2013 27' FB International
Blainville , Quebec
Belly pan paint or Bedliner???
Hello, i have 2015 airstream and i already have corosion on the belly pan. I took the trailer in november and store it for the winter and didn't wash the belly pan. So calcium did a litle corosion. I put some oil all over it, but I am tiking to paint it or put some Bedliner. Isit a good idea?
VW Touareg Diesel 2015
30´Airstream International 2015
27' Airstream 2014
25' Airstream 2012
20' Airstream 2009
Tino643 is offline   Reply With Quote
Old 04-25-2015, 07:33 PM   #2
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Painting would make it harder if you ever wanted to polish your belly pan!
Seriously, I don't think it would hurt anything. The bed liner would be thicker.
Silverflames is offline   Reply With Quote
Old 04-25-2015, 07:36 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I was contemplating using a product from reRubber on the belly pan of our Avion. I think it would work well.
Automotive Coatings
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 04-25-2015, 07:39 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It would be a miserable dirty job spraying bed liner on a belly pan, but if you did it right by sanding it well and used an epoxy (two part) bed liner it would last a very long time.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-26-2015, 06:47 AM   #5
aquinob's Avatar
Portsmouth , Virginia
The bellypan is like the underside of a car. It's not meant to be pretty, but to protect the frame and floorboards from excessive moisture and debris. Lots of SOB trailers don't have any pan, just some sort of clothlike covering.
If you're so inclined, you can try and clean it up and paint it with some type of paint or undercoating. Just make sure you don't try and seal it up totally on the bottom, you want any moisture that gets behind it to be able to leak back out quickly. If it were me, I'd concentrate on keeping the shiny side shiny and looking for any abnormal leakage on the bottom.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 04-26-2015, 07:21 AM   #6
1981 31' Excella II
New Market , Alabama
Get some stuff called Aluthane. It is an aluminum filled water cured urethane (silver) similar to POR15. I would hose off the belly pan to get dirt off and put this stuff on. It likes rough corroded surfaces. I would think the weight of bed liner would not be a good thing.
Perry
perryg114 is online now   Reply With Quote
Old 04-26-2015, 10:25 AM   #7
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
I keep mine coated with CorrisonX along with the stabilizers......in fact everything underneath the AS. I picked this tip up from reading/learning about Filliform corrosion prevention. It does leave a waxy residue but no rust or corrosion so far.
Landrum is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Bedliner spray on the top of the Argosy? atti_mac Clearcoat, Exterior Paint & Trim 11 09-17-2014 07:04 PM
spray on bedliner - input needed paul53 Off Topic Forum 7 04-02-2009 10:23 AM
Belly Pan paint or sealant? Zstream Belly Pans & Banana Wraps 8 09-09-2008 03:43 PM
Spray-In Bedliner for Floor?? Opinions please.. BigSky Floor Finishes 6 03-01-2007 09:31 AM
