Old 02-08-2010, 12:17 PM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Belly pan material question
I tried but cannot get the 5052 H32 in the .025 thickness locally. I can however get it in .032 thickness in a 4'X12' sheet for $57.00. Sounds pretty reasonable. I've seen that the .025 is recommended. Would it be unadvisable to use the .032???
SilverHoot is offline   Reply With Quote
Old 02-08-2010, 12:28 PM   #2
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
I hear the belly pan is very hard to work with, even at .032. So while there is no harm in having the thicker material, it may be very difficult to work with. oh, and $57 does seem reasonable.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 02-08-2010, 12:59 PM   #3
VIKING's Avatar
Boulder Creek , California
You will have a hard time with the thicker material, and the added weight doesn't help any. I say continue your search. There must be an aircraft place somewhere around redding. Look for an aircraft repair business or truck trailer repair place if nothing else works.
Rich the Viking
VIKING is offline   Reply With Quote
Source for new belly material TheProfessor Belly Pans & Banana Wraps 25 09-27-2010 11:09 AM
Belly Pan Rivet question Gregg S Ribs, Skins & Rivets 1 09-01-2009 08:30 PM
Belly pan off or on ? augier Belly Pans & Banana Wraps 6 08-08-2009 02:04 PM
belly pan hlink Belly Pans & Banana Wraps 10 09-16-2008 07:51 AM
Can you help? Water in belly pan question Eddy General Repair Forum 5 07-04-2007 06:10 PM
