Old 02-19-2015, 10:37 AM   #1
1989 34' Excella
Weatherford , Texas
Belly Pan Material
Does it have to be done in aluminum or is tin sufficient?
2001 Ford Crewcab XLT 350 Powerstroke Diesel 4X4
Figures don't lie but liars can figure
Stogiemann is offline   Reply With Quote
Old 02-19-2015, 10:49 AM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
I used aluminum. Never heard of anyone using tin.
BambiTex is offline   Reply With Quote
Old 02-19-2015, 11:18 AM   #3
1981 31' Excella II
New Market , Alabama
I assume by tin you mean galvanized steel? It could be done but an equal weight of aluminum will be a lot thicker and not as flimsy as steel. The tank pans are thick galvanized steel. You can do it, but it will add weight.
Perry
Old 02-19-2015, 11:45 AM   #4
batman's Avatar
1964 22' Safari
modesto , California
Stogiemann,
My .02
You can use almost anything you want to. Especially if it is just a patch.
However there are always things to consider with each choice we make.
Tinned metal, Galvanized metal are heavier and will rust at the drilled out rivet holes, after a couple years of moving and shaking it will be falling off.
Copper, no rust, has a severe galvanic reaction with aluminum
Stainless steal, $$$, no rust, very heavy and hard to work with.
Aluminum, Cheaper, no rust, light and easy to work with.
-Dennis
batman is offline   Reply With Quote
Old 02-19-2015, 11:49 AM   #5
1981 31' Excella II
Galvanized steel is not bad. The Zinc coating protects it and the frame from rust. Holes are usually not a problem because the zinc helps with those as well. Aluminum can corrode because of the steel frame and steel screws. Best to paint the frame with POR15 to electrically insulate the two different metals. I use stainless screws on everything. I hate rivets for places where you need to get back into periodically and inspect for damage.
Perry
Old 02-25-2015, 01:15 PM   #6
GlamperGirl
i bought 5052 .063 - 5 sheets. Am in the middle of the mess of the belly pan install as we speak. I POR-15 the frame. Using 3M 5200 in any holes. Used 1' band and fat flange rivets. It is a harder aluminum and hard to work with. Bought an English Wheel to make the bends. Lots of hours and mistakes in this.
Keep your old pan for template
Good luck!
thumbelinadj is offline   Reply With Quote
Old 02-25-2015, 01:22 PM   #7
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Too Thick?
Good luck!
I imagine it is pretty hard to work with in that thickness. I think that is thicker than the shell..
Old 02-25-2015, 02:02 PM   #8
1981 31' Excella II
That is way too thick. Bending won't be fun. I would go no thicker than .032 for the side wraps.
Perry
Old 02-25-2015, 02:43 PM   #9
1976 31' Sovereign
Oswego , Illinois
Why does AS put sides on then bannana wrap over side matl. causing many leaks then belt rail as was done on my 76 AS and no some else did not do this as I pur. new. Does AS still do this way? So if new wraps try to put under side skins or else seal very well.
Old 02-25-2015, 03:16 PM   #10
batman's Avatar
1964 22' Safari
Good luck!
Nice job! Wow, .063 is thick, heavy and expensive. That is almost twice the thickness of the outside panels (.032). Belly pan material can be thinner than the sides and no Alclad. An English Wheel, awesome. Must see photo's.
Old 02-25-2015, 03:35 PM   #11
batman's Avatar
1964 22' Safari
Featherbedder, the banana wrap is just a decorative band to cover the transition of the side panels to the belly pan. The banana wrap does not prevent or cause leaks. If you have leaks near your walls, it is most likely coming from a source up higher like a window seam, vent or skylight and runs down the inside of the wall. Not the banana wrap.
Old 02-25-2015, 03:41 PM   #12
GlamperGirl
You're right perry it is .032. My mind is going
Old 02-25-2015, 05:58 PM   #13
1981 31' Excella II
Zep made a jig for bending those side wraps. He used some PVC pipe which is what I used to bend mine. As far as corner wraps, those are really hard to make from scratch.
Perry
Old 02-26-2015, 08:17 AM   #14
1976 31' Sovereign
Oswego , Illinois
bannana wraps
When I pulled rub rail, side panels do not meet belly pan, also between rivets fairly large gaps in wrap. I do not have any leaks as top edge rub rail is well sealed with par bond, also no windows or door leaks, but my AS not exposed any extreme climate changes as put in heated storage since 1991 before cold weather comes.
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Seeking belly skin material shadeemry Belly Pans & Banana Wraps 17 09-27-2012 09:02 PM
Belly Pan replacement Material for a 1963 Bambi Aktundra Belly Pans & Banana Wraps 2 06-11-2012 04:29 PM
Source for new belly material TheProfessor Belly Pans & Banana Wraps 25 09-27-2010 11:09 AM
Belly pan material question SilverHoot Belly Pans & Banana Wraps 2 02-08-2010 12:59 PM
