Old 04-20-2015, 07:50 PM   #15
rowdyATX's Avatar
1956 26' Cruiser/Overlander
1961 28' Ambassador
Originally Posted by perryg114 View Post
Zep made a jig for bending those side wraps. He used some PVC pipe which is what I used to bend mine. As far as corner wraps, those are really hard to make from scratch.
Perry
Do you have a picture to show how you use the pvc pipe to bend the side wraps?
rowdyATX is offline   Reply With Quote
Old 06-21-2015, 12:40 PM   #16
54 Flying Cloud
KrisE MN's Avatar
1967 20' Globetrotter
1954 22' Flying Cloud
Grand Rapids , Minnesota
has anyone recycled good aluminum from non AS for belly wrap? I know of 2 very nice aluminum trailers w good sides for donor material. My dad suggested it and did sound viable
KrisE MN is offline   Reply With Quote
Old 06-21-2015, 01:25 PM   #17
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
While possible, with enough work, it could be done. It would be simpler and faster to just use new aluminum. Depending on how wide the sheets are on the donor, it would be best if there where at least 4' wide in order to rivet between two frame members. New 3003 sheets don't really cost that much.
Old 06-21-2015, 02:01 PM   #18
54 Flying Cloud
KrisE MN's Avatar
I liked the idea of recycling and there are plenty of long sheets without holes
Old 06-21-2015, 03:23 PM   #19
Aerowood's Avatar
Arvada , Colorado
Belly Pan Material
Sounds like you should go for it then
Old 06-21-2015, 07:48 PM   #20
1979 23' Safari
Wayland , New York
5052-h32 .032 thick. It's not to hard to find, check steel distributors/supply places. If you're lucky they'll have a sheer, plan the sizes you'll need, minus the curves you'll have to cut, and have them sheer it for you. Cost me $1 per cut and saved a lot of time and work. It can still be tough to bend around the side to the bottom.
Old 08-13-2015, 04:05 PM   #21
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
Perhaps a stupid question, but does anyone sell prefab (already bent) belly pan sections? Seems like there would be a decent market for such a thing, even if you were just making them as "one offs."
kidjedi is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Seeking belly skin material shadeemry Belly Pans & Banana Wraps 17 09-27-2012 09:02 PM
Belly Pan replacement Material for a 1963 Bambi Aktundra Belly Pans & Banana Wraps 2 06-11-2012 04:29 PM
Source for new belly material TheProfessor Belly Pans & Banana Wraps 25 09-27-2010 11:09 AM
Belly pan material question SilverHoot Belly Pans & Banana Wraps 2 02-08-2010 12:59 PM
