Old 09-28-2012, 03:22 PM   #1
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Belly Pan issue
I have a 73 Argosy I just purchased and am beginning to start some repairs. The first issue is that the rivets holding the belly pan in place have evidently eaten away the belly pan in spots, and the pan is flopping loose in places. I don't want to take the whole thing off. Since the holes around the former rivet heads are up to 1/2" in diameter, re-riveting won't do much good. I'm thinking of taking 1-1/2" wide strips of plastic or fiberglass and placing the strips over the rivets and non-rivets, effectively sandwiching the riveted areas between the plastic and the frame. Suggestions?
I think I've attached an image of the pan.
DryFly is offline   Reply With Quote
Old 09-28-2012, 03:56 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
If your not doing more work and looking inside....just drill new holes and re rivet. You don't need to use the old spots.
Old 09-28-2012, 03:59 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Or you can get rivets with big "heads", essentially a rivet with a washer, or use rivets and washers...
Kay
Old 09-28-2012, 04:32 PM   #4
DryFly's Avatar
1972 Argosy 20
That was quick! I've never worked with rivets, does it take a special tool and special rivets? Could I use washer head screws instead?
Thanks so much for the input
Old 09-28-2012, 05:51 PM   #5
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Don't ever use screws on a belly pan. Guaranteed to vibrate out.
Old 09-28-2012, 05:57 PM   #6
1981 31' Excella II
New Market , Alabama
Just get some scrap aluminum and make some 2"x2" squares. All you need to do is drill some holes in them and use them as big washers.
If you really care about the trailer take the skins off and remove all the stinky wet pink insulation. This stuff will rot the frame if it has not already done so. If you want a quick fix then do the above.
Perry
Old 09-28-2012, 08:17 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
These are specifically made for belly pan attachment:
Large Flange Rivets
You can use a regular rivet gun with them. EASY!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-28-2012, 09:09 PM   #8
Minno's Avatar
1972 31' Sovereign
Yes, those are the rivets we used to attach our belly pan! (didn't know the name).
Kay
Old 09-28-2012, 09:13 PM   #9
Minno's Avatar
1972 31' Sovereign
Oh, and yes you will need a rivet gun to attach rivets. Pneumatic is easier to use on a belly pan (when you're laying on your back on the ground) than manual, but either will work.
Kay
Old 09-29-2012, 06:36 AM   #10
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I used some 3/4 wide flat alum stock to make lath strips. I riveted them along the cross members on the outer surface of the belly pan.
The flat stock is available at any lumber yard......
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-05-2012, 05:36 PM   #11
DryFly's Avatar
1972 Argosy 20
I've been doing some research on this issue and need to question the use of rivets vs self tapping screws. Are screws really subject to falling out due to vibration? My experience with self tappers into steel is that once installed they provide a very positive and seemingly lasting connection. I can certainly understand using aluminum rivets to attach to the aluminum frame on the body, but it seems to me that if vibration was really an the issue, a simple drop of loctite would take care of the problem. What other reasons are there to use rivets to re-attach the belly pan?
Old 10-05-2012, 06:02 PM   #12
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
A wide-flange rivet will remain in place and clamped until there is no longer steel to hold it or until the aluminum sheet disintegrates around the flange even if there is hundreds of hours of vibrations & shocks.
