Old 08-25-2010, 11:57 AM   #1
1975 31' Sovereign
Waterloo , Iowa
belly pan in sections or one piece?
As I cannot find aluminum in the 60 1/2" width that my original one is I imagine the way to go is 4'x12 sheets cut into sections. I would appreciate any input re this method, sizes etc.
Robert
robertel is offline   Reply With Quote
Old 08-25-2010, 12:05 PM   #2
x
XXXX , XXXX
Inland RV in California can supply belly pan in that width. $788.70 for full roll enough to do 31 ft as
wasagachris is offline   Reply With Quote
Old 08-25-2010, 01:06 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Your pan is somewhat longer then my 21 footer but I pieced mine together cutting 4x12 sheets of .040 5052 in 60" widths. Easier for me to handle that size sheet and makes it much easier to access the tanks etc.
Old 10-20-2010, 04:32 PM   #4
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
sections
So basically you are mounting the pan horizontally in 4 ft.x60" sections ?
Since I have to modify bp for tanks that hang down about 3" this seems like the best way if there is no urgent reason to run 2 single sheets seamed in the middle to run the length of the trailer.
bwaysteve is offline   Reply With Quote
Old 10-20-2010, 05:12 PM   #5
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
Where did you obtain 4x12 sheets of .040 5052 in 60" widths and how did you cut it (no shear)? How many sheets does it take to make belly pans for 22' AS?
Safari64 is offline   Reply With Quote
Old 10-20-2010, 05:31 PM   #6
Baltimore , Maryland
AirParts is my aluminum supplier. I use .025, for it is easier to work around the curves.
Old 10-20-2010, 05:35 PM   #7
toastie's Avatar
1955 22' Safari
Great Lake State , .
Robert
Check this out, great people to work with.......
5052H-32 ALUMINUM SHEET FOR FUEL TANKS from Aircraft Spruce
toastie
toastie is offline   Reply With Quote
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 21 08-29-2010 04:56 PM
Belly sections bwaysteve Belly Pans & Banana Wraps 8 04-05-2010 09:22 PM
Belly pan off or on ? augier Belly Pans & Banana Wraps 6 08-08-2009 02:04 PM
belly pan hlink Belly Pans & Banana Wraps 10 09-16-2008 07:51 AM
belly pan removal skip Belly Pans & Banana Wraps 6 08-17-2003 06:58 AM
