Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 09-13-2003, 05:34 PM   #1
Cruiser's Avatar
Profile:  1952 25' Cruiser
Brattleboro , Vermont
Images: 49
removing corroded belly pan screws
We're about to install a new belly pan. The old pan had corroded around the screws that were holding it onto the frame and was hanging down. The old pan came off, no problem, but the old screws are still in the frame . I assume these need to come out, so as not to abrade the new pan, but I haven't been able to get any of them out. Each screw makes a corroded sandwich of aluminum and steel that won't accept any screwdrivers or pliers and has resisted drilling and a sawzall. Is there a good way to get these out or should I just leave them as is?
Doug
Cruiser is offline   Reply With Quote
Old 09-13-2003, 05:40 PM   #2
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , Texas
Images: 143
Dutchmen
A small handheld 4" grinder might do the trick.
Dennis
WBCCI # 1113
AirForums #1737
Old 09-14-2003, 12:17 PM   #3
Cruiser's Avatar
Images: 49
Thanks, Dennis, I'll try the grinder.
Doug
Pingbacks are On
Belly Pan Aluminium Streamsaver Belly Pans & Banana Wraps 3 01-17-2004 10:59 PM
belly pan corners tonyg Belly Pans & Banana Wraps 0 09-21-2003 04:14 PM
belly pan removal skip Belly Pans & Banana Wraps 6 08-17-2003 06:58 AM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 2 08-30-2002 12:27 PM
SEO by vBSEO 3.1.0
