Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 09-27-2009, 04:40 PM   #29
gutsgolf's Avatar
Profile:  1972 31' Sovereign
Alexandria , Louisiana
Send a message via AIM to gutsgolf Send a message via Skype™ to gutsgolf
Thanks Jim,
I actually thought about cutting that thing in half. Those axles have it locked tight. I got frustrated and tried to cut around one axle . big mistake , well i am learning. Don't think I got that much tug power in me. well got to go back at it .
wish me luck.
Richard & Marika
31' International
Land Yatch
"Silver Belle"
AS 16741
gutsgolf is offline   Reply With Quote
Old 09-27-2009, 07:28 PM   #30
Minno's Avatar
Lexington , Minnesota
Maybe this would help?
I’m thinking maybe you would be better off cutting the belly pan into 3 pieces. Make one cut just before the axels, and then another cut after the axels. Then you can fairly easily remove the front and rear pieces, and hopefully, flex the remaining piece enough to get it out from the axels.
When they build these puppies, the axels are installed after the floor and belly skin, which explains why things are the way they are now when you’re trying to remove it.
When you reinstall the belly skin, you’ll have to seam where you made the cuts. To do that, cut about a 4 or 6 inch wide strip of sheet aluminum and use that, along with pop rivets, to make the seam. If you can make the cut near one of the cross pieces that the belly is riveted to, then the seam reinforcement piece will be supported by additional rivets when you re-install it. Hopefully that makes sense.
The belly skin doesn’t need to be completely water tight, or necessarily really pretty, so having the extra seams would not be an issue. Plus, they might come in handy down the road if you need to get access up there again.
Just a thought.
Chris
Old 09-27-2009, 08:34 PM   #31
gutsgolf's Avatar
that sounds like a great idea. i shoved the brake wires up in there before i realized how bad that thing was going to be to get out. When i got to the back the sheet of metal that goes under the storage area was over the belly pan. it had caught on low curbs and spots had been pulled down an inch or so. would you put the pan over that so it will slide
Richard & Marika
31' International
Land Yatch
"Silver Belle"
AS 16741
Old 09-28-2009, 01:49 PM   #32
Minno's Avatar
Not sure I understand your question.
Chris
Old 09-28-2009, 07:26 PM   #33
Profile:  1964 22' Safari
enosburg , Vermont
If you are going to leave you axles in place it seems you'll have to slice the pan. No biggie, lot of folks do. As suggested above pop rivit alum strips on the inside of the pan to rejoin the sections you cut. Saging sections are common, the small rivit heads pull through. When you reatach use the lg dia. head rivits, 1/2 inch head I believe. Belly pans are supose to "leak", only place water can escape. The rivits I've seen holding the pan to the Xmembers are 3/16 dia. not 1/8. Look close when you drill, sometimes the whole rivit spins. Which way do your seams run, lengthways of the frame or crossways? Get ahold of Mike [?] on "dirtiest jobs" vidios! Your doing the absolout dirtiest, filthiest, most misserable job in the Airstream resto world and nothing showes for your effort when your done! But its the foundation for everything after that do'es show. And you will never give a second thought to any weakness under the floor.
putback is offline   Reply With Quote
Old 10-28-2009, 03:25 AM   #34
Profile:  1960 24' Tradewind
KINGSLAND , Georgia
Xyvek might work--it's waterproof from the outside but allows water vapor to escape from the inside.
k4ter is offline   Reply With Quote
Belly pan off or on ? augier Belly Pans & Banana Wraps 6 08-08-2009 03:04 PM
Belly Pan insulation Ron Banks Belly Pans & Banana Wraps 1 02-11-2009 10:48 AM
belly pan hlink Belly Pans & Banana Wraps 10 09-16-2008 08:51 AM
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 16 07-18-2004 09:16 PM
Belly Pan Gaps? ajjohnsons 2003 Safari 6 07-22-2003 08:16 PM
