Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 03-04-2017, 08:59 PM   #1
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Belly pan blues!!!!!
What's the secret to a nice belly pan install? To start with my 57 Flying Cloud belly pan was long gone before I got it so I'm trying to recreate without any type of pattern.
Talk about frustration!
I did get the front corners pretty good but the rear corners are more difficult with rear bumper in the way.
Any tips, ideas and or comments welcome please.
Anyone have patterns I could borrow?
Pictures coming
https://flic.kr/p/RoaVXb
https://www.flickr.com/gp/desertair/86BdwZ
desertair27 is offline   Reply With Quote
Old 03-07-2017, 11:22 AM   #2
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
So here's some pictures of where I was at.
Old 03-07-2017, 11:33 AM   #3
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
So I took some untimely away from project and came back with a fresh attitude.
I somehow figured out that I needed a little weight on the end of my rear corner belly pan.
I placed a small piece of a 4x4 on the belly pan end. It was like magic, the belly pan fell into place and showed me where to trim etc.
I'm in the figure it out the hard way mode and today's lesson is the 1/4 bolts I added to the c channel perimeter have to be installed upside from how I installed.This picture shows belly pan messed up from the bolts.
Next picture shows curbside corner before belly pan install with bolts in the correct direction to prevent any issues like I had with this side"
Oh well at least I have a usable pattern for attempt number 3 on this piece.
Practice makes perfect hopefully.
Old 03-07-2017, 12:14 PM   #4
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Tank cover?
More time off from the frustrating belly pan,decided to attempt an aluminum cover for my grey tank that extends out of belly pan.
ID:	281003   Click image for larger version
Old 03-07-2017, 03:47 PM   #5
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Grey tank
Grey tank before cover
Old 03-07-2017, 03:54 PM   #6
millertimeUS's Avatar
1976 25' Tradewind
Looking nice man, good thing you have some sheet metal skills unless it is flat work I always have to outsource most metal fabrication
Matt
millertimeUS is offline   Reply With Quote
Old 03-22-2017, 09:41 PM   #7
1959 24' Tradewind
Twin Falls , Idaho
Yeah, looks pretty good to me. I'll be in your boat soon enough, so I'm trying to find out all I can.
Keep up the good work and the pictures help a bunch.
Regards,
Tony
Trons4u is offline   Reply With Quote
Old 03-22-2017, 09:50 PM   #8
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
I'm not sure how much it would help but in the thread "Super Sized Sixty Sovereign" starting at post #56 I wrote a brief how to for belly pan corners.
truckasaurus is offline   Reply With Quote
Old 12-13-2017, 05:50 PM   #9
I tow where I'm told.
MrRivet's Avatar
2004 28' International CCD
1948 22' Liner
1963 22' Safari
Oakland , Florida
Looking Good! Was wondering what size grey tank you installed and manufacturer? We have just started our restoration of our 1948 Liner and we are going to be installing holding tanks into a new frame.
MrRivet is offline   Reply With Quote
Old 12-13-2017, 06:06 PM   #10
1966 22' Safari
Fredericksburg , Texas
That looks great. My first few attempts didn’t go so well. I had to do mine from underneath since I didn’t flip the chassis. I did have a roll of aluminum jacketing for chill water lines. I used that as a pattern for the corner cuts. We used a lot of C-clamps on the C-channel, trimmed the access then riveted. I think that was the most frustrating thing so far. Good luck. Bubba
Bubba L is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
belly pan removal skip Belly Pans & Banana Wraps 6 08-17-2003 06:58 AM
Belly Pan Gaps? ajjohnsons 2000 - 2004 Safari 6 07-22-2003 07:16 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
