Old 04-22-2013, 03:43 PM   #1
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
Hillpoint , Wisconsin
Belly pan blow out!
I had my 1973 Argosy hauled home today and it showed up with the front 1/3 of the center belly pan section torn away from the bottom of the trailer. An area was tore loose by the last owner to get at the wiring I guess and I did not think it would self-destruct this much on the 30 mile trip home on a flat bed. My first thought was to just cut it off that part that is hanging down because I can’t move the trailer right now without running over the loose belly pan and I don’t think I want to try and reattach it since I will be replacing some of the floor above it. Is there any big down side to having it sectioned into 2 or 3 pieces when I put it back up?
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
and a partridge in a pear tree
Sprouty is offline   Reply With Quote
Old 04-22-2013, 03:53 PM   #2
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
I should clarify I am talking about 2 or 3 section for the whole length of the trailer not just the loose part.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
Old 04-22-2013, 04:07 PM   #3
strshpntrprz's Avatar
1973 23' Safari
Reese , Michigan
Some creative work with a couple cheap ratchet straps from front axle to tongue should make it mobile while the thought processes go on.
Gene and Sharol in starship enterprize (earthbound) don't grow up, it is a TRAP ---repairing, not restoring since 1999
strshpntrprz is offline   Reply With Quote
Old 04-22-2013, 04:17 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Mine is in multiple sections attached with screws...for a reason.
Aaron
WBCCI #XXXX AIR #2495
Old 04-22-2013, 05:29 PM   #5
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
I backed it up and stuck some jack stand under 2x6 boards under it to hold it up for now. Its really not in that bad of shape but for the holes where the rivit heads pulled thru. I like the ratchet strap idea I will try it.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
Old 04-22-2013, 05:31 PM   #6
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
Aaron
I more I think about it The more I like the idea of sections that I can remove for inspection and service.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
