Old 07-24-2004, 11:53 PM   #1
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
belly pan aluminum? where?
Forgive me if this has been asked and answered a million times.
We need aluminum for our 1967 24' belly pan. We haven't jacked it up yet but we're shopping around for repair aluminum so we can fit it into our budget, so we don't know how much we'll be buying yet. We might just need to repair, we might need to replace all.
The VAC resources link says "non-alclad, .024 2024T3", that is fine, but is that just a quote of what Airstream originally used? Because if there is something else that is cheaper and will work fine, we're all over it :-)
I've already been given the link to www.airpartsinc.com by KenJ (thanks KenJ) and I'm under the impression different types can be used.
We live in the East San Francisco Bay area (in other words, Oakland/Alameda) and will drive to save shipping costs...if anyone knows of an aluminum place out here let us know.
Open to all suggestions.
KenJ; let me know what you find out about those other types.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 07-25-2004, 12:21 AM   #2
greg176's Avatar
Gabriola Island , British Columbia
Ingrid, I would not use non alclad 2024 as the alclad is there for corrosion prevention.2024 is very susceptible to corrosion because of it's copper content.I bought my aluminum from Airpartsinc as I needed pieces longer than 12' and they can ship a roll up to 32' long.Also the shipping cost on that roll is much cheaper than with sheets so I may buy another roll soon.A source nearer you is http://www.aircraft-spruce.com/ they are a little bit more expensive than Airparts but the saving on shipping may offset that.The cheapest aluminum I found was at www.wicksaircraft.com but they could not supply me with pieces over 12'. On a positive note I do not believe your trailer was made with 2024 and suspect it is made of either 5052 or 6061-t6 but I cannot say which.I have put the question out there several times but have not got a definitive answer.Maybe call or pm Andy. Those metals are much cheaper than the 2024 although not as strong.I would also suggest that you check the yellow pages in your area for metal suppliers although they were no help here.
greg176 is offline   Reply With Quote
Old 07-25-2004, 08:15 AM   #3
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Ingrid
If you go with 6061 or 5052 I would think you could find that locally - as Greg suggested look in the yellow pages - should be able to find some. My understanding is 2024 is expensive when purchased from local shops and even with shipping, Airparts or Spruce will be less expensive.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 07-25-2004, 10:30 AM   #4
Obsessed with Moonunit
COArgosy78's Avatar
1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 55
We ended up getting a 4x8 piece of 5052 @ .032 thickness for repair to the underside of our trailer for $40. locally. There was a pretty good list of places that did sheet metal work and thru a little perserverance I persuaded one to sell us a sheet they had on hand. I did find another place that would sell it for about $45., but we would have had to drive out of town. I may have to do that next time, tho as the local place wasn't real enthusiastic. Anyway, looking under Sheet Metal Fabricators or Sheet Metal Work in yellow pages might work for you too. Good luck.
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
COArgosy78 is offline   Reply With Quote
Old 07-25-2004, 12:14 PM   #5
1967 24' Tradewind
Images: 38
Yay, there's better stuff for less money. I think you're right about the .032, and I'm sure we'll be able to find something.
So; alclad is better than nonalclad?
~ Hurley
ingrid
Old 07-25-2004, 12:42 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Talking Fwiw
The 1975 models use 3004 Aluminum in an .024 for the belly pan, mine is 61.5" wide and 280" long Still on the trailer, one of these days it will have to be dropped and possibly replaced.
Aaron
WBCCI #XXXX AIR #2495
Old 07-26-2004, 01:31 PM   #7
COArgosy78's Avatar
Images: 55
Its my understanding that if it is clad, then it is not totally aluminum (probibly some copper mixed in) and the clad is so it won't oxidize. But, if it gets scratched, it will start to corrode at that entry point, so you are paying for something you don't need.
Old 07-26-2004, 06:18 PM   #8
1973 31' Sovereign
Portland , Oregon
Images: 22
Where to get 61.5" wide aluminum?
I have asked this before with no response...
My 1973 also has 61.5 inch wide belly pan aluminum. Does anyone know where I can get replacement aluminum that wide? Or should I just plan to do the belly pan with 48" strips run cross-wise?
Malcolm
malconium is offline   Reply With Quote
Old 07-26-2004, 06:46 PM   #9
Ken J's Avatar
Durango , Colorado
Images: 14
I would just do strips cross wise. That way if you ever need to get to a particular section you can do so without taking the whole pan down
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 07-28-2004, 09:44 AM   #10
Also, check with local machine/fabrication shops or if you know someone who has a working contact with a shop. If the shop can get the type and size of material that you need from their normal suppliers then it would come in on a normal supply shipment. You may be able to get what you want for a better price that way.
dbm04F250 is offline   Reply With Quote
Old 07-28-2004, 02:22 PM   #11
1967 24' Tradewind
Images: 38
Will do. My neighbor across the street was a machinist for years, maybe he knows a source. The local metal fab shop is overpriced, but there are a lot of others in my local area I haven't tried yet. I also have the web as an option if need be!
~ Hurley
ingrid
Old 07-28-2004, 05:17 PM   #12
Belly pan Aluminum
I just bought 5052 .025 thick for my belly from Airparts. The original was .025 and 5052 is cheap and corrosion resistant.
jperryfly is offline   Reply With Quote
Old 07-28-2004, 06:01 PM   #13
greg176's Avatar
I just ordered two more 32' rolls of .032" 2024-t3 from Airparts.Also went to local metal recyclers called ABC Traders.Have been checking there for about a year with no luck, then yesterday they had three sheets of 2024-t3 .032".I bought all three for $45US each.They have a lot of 028" that I might get if I need more.With the old trailer I do not want to mess around mixing alloys.Now all I have to do is smack a few rivets.Wish me luck.
Old 07-28-2004, 08:07 PM   #14
Ken J's Avatar
Durango , Colorado
Images: 14
Are these rolls gonna be used for reskinning? I looking forward to following your progress. Are you going to use the 2024 for belly skin also?
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 21 08-29-2010 04:56 PM
removing corroded belly pan screws Cruiser Belly Pans & Banana Wraps 2 09-14-2003 12:17 PM
belly pan removal skip Belly Pans & Banana Wraps 6 08-17-2003 06:58 AM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
