Old 07-28-2004, 09:24 PM   #15
greg176's Avatar
Gabriola Island , British Columbia
I will be replacing the belly pan, all the lower exterior panels and three or four interior panels.
greg176 is offline   Reply With Quote
Old 07-28-2004, 10:24 PM   #16
JohnG's Avatar
What kind of price tag does a roll go for and how much is shipping?
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-28-2004, 10:28 PM   #17
JohnG's Avatar
I don't know what kind of aluminum is used for roof on a semi trailer, but I do know that it is a single piece and trailers are 53 ft long and 110" wide so I would think that one could get any size they needed from a trailer repair facility. It should be corrosion resistant also, but I don't know this for sure.
Just thought I'd throw the idea out there.
John G
Old 07-29-2004, 08:31 AM   #18
greg176's Avatar
A 32' roll of 2024-t3 .032" from Airpartsinc costs $410 and shipping was about $50.The 5052 would be about half that.
Old 07-29-2004, 11:43 AM   #19
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Interesting thread. I've been thinking about replacing the skin on my 67 Globetrotter and have seen that the belly on mine is coated with a rough, semi hard silvery substance of unknown origin. Is this factory? Did a PO spray something on there? I first thought it might be chip coat or sound deadening coating but then I thought, WHY?
Any thoughts?
Tom.
Tom Nugler is offline   Reply With Quote
Old 08-08-2004, 03:50 PM   #20
blrpix's Avatar
rough belly
Any thoughts?
Tom.
Mine is a 65...looks the same as Tom describes...I need to replace some of it, so any info would be appreciated!
blrpix is offline   Reply With Quote
Old 08-09-2004, 04:34 PM   #21
Images: 59
Originally Posted by malconium
My 1973 also has 61.5 inch wide belly pan aluminum. Does anyone know where I can get replacement aluminum that wide? Or should I just plan to do the belly pan with 48" strips run cross-wise?
Malcolm
Malcolm,
I'm thinking of a different method. I'm going to replace the outside 24" on both sides. That gets me just inside the frame rails. From there I will rivet to the original material, which is in good shape after trimming off the banged up outside edges. This way I don't have visible seams showing.
Also, check the dimensions on the crossmembers. Several of mine are 24" oc, so a 48" sheet won't span two full crossmembers and leave enough for a good overlap joint.
Old 08-09-2004, 07:06 PM   #22
1973 31' Sovereign
Portland , Oregon
Images: 22
Oops! 48" OC is what I have...
Don,
I can't imaging why the 48" o.c. item missed my attention! I know for a fact that my cross members are all pretty much at 24" o.c. yet I just bought aluminum that is 48" wide (I still can not find a source of 61-1/2" wide stuff). I even had the pieces pre-cut for me to 60" long for a cross-wise install. I could have ordered strips that would have been good for a lenghwise install with a seam down the middle. I don't think having a butt joint at each cross-member is all that bad except that the bottom of my cross-members is not all that wide. I think I would have trouble getting enough surface to do a double row of rivits to fit along the bottom edge. The two solutions that come to mind are:
1.) Add something on the bottom of the cross-members (perahaps a strip of aluminum 2" or so wide) where the joints will occur and rivit the belly pan to it. I remember noticing some light weight galvenized angle flashing the other day at Home Depot that I could perhaps use to attach to the side of the cross-member (thereby avoiding creating bumps on the bottom of the cross-members).
2.) Add some sort of trim strip to cover the joint in the belly pan pieces after the belly pan is in place. Maybe I can find something that I can slip the belly pan pieces into something like the track that is along the edges of the inner skin top center piece.
My guess is that I will end up going with number 1 above unless someone has some creative thinking that I can apply here.
Malcolm
malconium is offline   Reply With Quote
Old 08-09-2004, 07:30 PM   #23
Images: 59
Malcolm,
Sorry I didn't notice this problem earlier, I have just started trying to figure out how much of my belly pan is salvageable and how much I had to order when the alternative solution I posted occurred to me. I was planning to do a total replacement until I found out what it cost.
I think your solution #1 sounds good. The advantage of a bridging strip is that if it corrodes due to contact with the steel crossmember, you can replace it easily.
Old 08-11-2004, 03:33 PM   #24
1973 31' Sovereign
Portland , Oregon
Images: 22
Use strips from the old belly pan...
I think what I will probably do is use some strips cut out of my old belly pan (if I can find some places that are solid enough). There are not actually that many joints that I have to worry about. I am only replaceing about half of the belly pan.
Malcolm
Old 08-21-2004, 05:54 PM   #25
blrpix's Avatar
Exclamation Drop the pan
Everyone has great ideas so keep posting! I plan to drop my whole pan and replace all of it...want to start from the ground up...and I need to do some work with the pan off. I like the idea of the sections so I can get into different areas of the belly if I need to do repairs, etc. (instaling a grey tank, so for maintainence, etc). This makes the idea of strips and 48" OC apealing. Then every two crossmembers are accessable. Also what about the idea of something between the frame and the aluminum belly, so they don't touch? This peice could be the peice that the 2 48" pieces are attached to...I don't think you would need a cover peice if the backing peice they attached to was 2" wide running along the frame, but what this is and how it attaches to the frame is another story(Steel welded to the frame and then a barier)? Also, has anybody thought about using ALL srews instead of screws and/or rivets so the panels can be dropped easily? I was thinking of the galvanized ones with the rubber washers behind the metal washer, so no steel touched the aluminum? Lastly, what about the curved sections on the corners? How are those repaired/replaced? Straight sections seem easy...Any/All ideas appreciated...the Forum rocks!
Old 08-21-2004, 08:17 PM   #26
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
I've used stainless steel screws to attach the belly - works fine, you have to watch them though because they sometimes will loosen - I've also used - gads - silicone (the ONLY place I use silicone on the trailer) on the screws to keep them from coming out.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 08-21-2004, 09:26 PM   #27
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
rough belly answers anyone?
Hey Tom Nugler and blrpix, did either of you get an answer on the rough coating stuff on the belly? Mine looks like that too.
I have yet to get the trailer up on ramps to even look at the underside. We're debating a different method than building wood ramps but my husband is convinced the whole trailer is going to fall on me like a bad cartoon, "whump". But I'm still watching this thread, and could you all be sure to post pix of belly pan replacements, and let us all know when you have done that? It's our very next move, this century.
pf
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 08-21-2004, 09:46 PM   #28
JohnG's Avatar
pf
As long as you don't make your ramps too high you should be safe. I'd never go up higher than 12" and then the wood would have to be 8" at the bottom or so. I guess you could attach a sort of A frame to it to lend side to side support. However if you make it that high really watch what your doing when you pull the trailer up on it. You really want to be center (Side to Side) if possible on those ramps. That will keep all the force going straight down and not starting to lean the wood over.
John G
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 21 08-29-2010 04:56 PM
removing corroded belly pan screws Cruiser Belly Pans & Banana Wraps 2 09-14-2003 12:17 PM
belly pan removal skip Belly Pans & Banana Wraps 6 08-17-2003 06:58 AM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
