Old 09-25-2016, 03:43 PM   #1
CabMan
1960 22' Flying Cloud
Sunlakes , Arizona
Belly Pan
Can anyone show me a pic of how the belly pan should finish up around the dump valve on the street side exit. The valve and toilet are about 4 ft forward of the rear corner
Thanks Cabmike
cabmike1954 is offline   Reply With Quote
Old 09-25-2016, 06:55 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I installed a belly pan on a 69 Globetrotter with a "belly dump" port. I might also add that the belly pan on my 66 Trade Wind had a "fresh water port" on the bottom that you threaded the fresh water hose through.
In both cases I cut to fit what was needed. Maybe you can post of picture of the area on your 60 trailer.
Here is a photo of the rear corner belly pan segments. They are a bear to make with the compound curve and all.
David
Name:	1603 Belly Pan Old.jpg
ID:	272342   Click image for larger version
Name:	1311 Belly Rear Wraps.jpg
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 09:43 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 01:48 PM
belly pan removal skip Belly Pans & Banana Wraps 6 08-17-2003 07:58 AM
Belly Pan Gaps? ajjohnsons 2003 Safari 6 07-22-2003 08:16 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 07:03 PM
