Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 04-02-2003, 08:38 PM   #1
2019 19' Flying Cloud
Costa Mesa , California
Belly Band on 31' 1978 Exella
I am new to this forum. I am currently polishing (having polished) my Airstream that we have owned for 15 years. I am looking for someone withn the original dark blue and light blue stripe on aa 78' Exella. I need the width dimensions as they were remove befor I was able to get the dimensions, I have the rear panel but not the side stripe. Thanks for your help!
Jim Miller is offline   Reply With Quote
Old 04-03-2003, 07:38 AM   #2
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
i noticed that on ebay someone has the trim up for auction. search airstream. or call sonny at 205-665-2531 he is a airstream parts dealer and he might have it if not he could tell you which size you need.
lol
al
wb13798 is offline   Reply With Quote
Old 04-03-2003, 12:31 PM   #3
Thank! I'lll give him a call.
Old 04-03-2003, 01:33 PM   #4
startrekker2001's Avatar
1978 31' Excella 500
Palm Bay , Florida
Images: 34
Belly Band.
I have a '78 31' Excella. See photos.
Try www.inlandrv.com. Then click on PARTS and then 'find' INSERT. That will get you to the 1/2 inch blue insert that goes around the vinylclad aluminum band. A 50' roll is $30. The 11/8 inch wide 50' roll for the bottom rub rail is $40. If you are talking about the 81/4 inch wide vinyl clad aluminum blue band, good luck. Those are not available as far as I know.
If the wide vinylclad is in bad shape, you can paint it with Rustoleum Royal Blue. It is a perfect match. I used a 4" smooth foam roller and it did a credible job. Others may disagree.
Vic
Vic Smith
Director Florida State Rally
www.floridastaterally.org
www.facebook.com/FloridaStateRally
WBCCI Florida Unit 027 Trustee
https://www.airstream-adventures.com/...rida_Unit.html
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Old 04-03-2003, 01:47 PM   #5
Cool Balley band
Vic,
Thanks for the response! I am talking about the wide band, but I have the 3M vinyl cutting equipment so I can reproduce the stripe if I can get the dimensions. The stripe I am looking for is the light blue one you removed from your trailer.
Your trailer looks awesome and has me excited to finish mine!
Is your trailer hard to keep that shine? How do you do it?
Thanks!
Old 04-03-2003, 05:43 PM   #6
1962 19' Globetrotter
2001 31' Excella
Jim,
Is this the stripe you are talking about? If so, I can measure mine this weekend and let you know then.
As you can see, mine is in bad shape and I plan to remove it like Vic did.
Craig
Name:	blue stripe.jpg
Craig is offline   Reply With Quote
Old 04-03-2003, 09:00 PM   #7
Cool Belly band
Craig,
Thats exactly it! This forum is a fantastic way to learn things about our A/S, thanks for the photo. I would appriciate it if you can mearure yours for me. If you would like I can see how much it would cost to send you a replacment stripe. I have a sign company I do a lot of buisness with, he may give me a good price.
Thanks again!
Old 04-04-2003, 01:32 AM   #8
pap
Jim the wide blue stripe is nowhere near the belly of the Airstream.
Measuring the blue stripe would entail guessing how much of it is actually under the extrusion molds at the top and bottom of it. It is an aluminum overlay piece. or Do you want the measurements of the white accent stripe which is apparently a decal on top of the wide blue band? My 74 Excella thankfully does not have that 'bad boy' stripe applied.
Then there are the narrow blue vinyl inserts which are slotted into the extrusion mouldings.
pap is offline   Reply With Quote
Old 04-04-2003, 06:19 AM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
depending on if you are wanting to keep to exact originality or not, if you search "tape striping" and tape stripe, etc on EBAY you can get rolls of really nice 3" wide tape to fit that area. I did mine in a different color than the original, that did match the other colors on my motorhome. Got 150 foot roll for 30 bucks. Looks really good, and was not too hard to accomplish.
Old 04-04-2003, 07:15 AM   #10
Tahkns Pap! I'll check that out
Old 04-06-2003, 12:55 PM   #11
Rivet
Craig,
Have you had a chance to measure the stripe on your trailer yet. The one in the picture is exactly like mine.
Old 04-06-2003, 01:40 PM   #12
2001 31' Excella
I was just getting online to respond!
The stripe is almost exactly 1 1/4", with a 1/4" strip on top and bottom.
Hope this helps. Let me know how you make out. And yes, let me know how much to replace the stripe - I may be interested.
Craig
Old 04-06-2003, 04:18 PM   #13
Smile
Thanks Craig! I'll get back to you next week.
where belly meets floor meets shell JrnymnJay Repairing/Replacing Floor &/or Frame 6 01-09-2006 12:05 PM
belly pan removal skip Belly Pans & Banana Wraps 6 08-17-2003 06:58 AM
Airstreams: 1978 versus 1984 drboyd General Repair Forum 3 06-22-2003 06:07 PM
