Old 10-16-2004, 07:21 PM   #1
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
banana wrap: salvageable?
Or do you think we should just toss and cut another?
And...how exactly do you remove the rivets that don't have a belly button? The ones with the little holes in the middle are easy...what do you do about these?
pictures attached. Thanks,
ingrid
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 10-16-2004, 07:51 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
$.30#?
Ingrid,
That wrap looks like toast to me, but.... As far as removing bucked rivets...they make a self centering drilling tool that works great!...but I can't find the link! FOUND IT! I think I bought mine from Aircraft Tools If your eyesite is decent you can generally get close enough by eyeballing. But if you have a bunch of rivets to drill out or wear bifocals these tools are the only way to go.
Aaron
WBCCI #XXXX AIR #2495
Old 10-17-2004, 10:20 AM   #3
Mike B's Avatar
1977 23' Safari
1976 31' Sovereign
Robbins , California
Banana wrap
ingrid
Ingrid,
You could slowly work that back into shape with a small hammer. I had one that bad on our 31. The front right corner of the trailer got hit by a tire that had come off a car on the freeway and bounced up and hit the trailer while going down the road. It wiped out the wrap and the curved sheet panel on the trailer. I pulled the wrap off and slowly worked the panel back into shape . Neither are perfect but look pretty good. It just takes time and paitence. The wrap would not be a easy piece to replicate out of sheet because of the curves in it. If all else fails you could just buy some of the plastic replacement wraps.
Mike B
Mike B
1977 23' Safari
1976 31' Sovereign
1996 F350 CC PSD
Mike B is offline   Reply With Quote
Old 10-17-2004, 02:28 PM   #4
1967 24' Tradewind
Images: 38
Originally Posted by Mike B
Ingrid,
Mike B
How awful do the plastic replacements look?
I think I'll try to fix the wrap before tossing so I can be sure.
Thanks both,
i
~ Hurley
ingrid
Old 10-19-2004, 09:57 PM   #5
1973 31' Sovereign
Portland , Oregon
Images: 22
Another rivit removal tool source...
I bought my rivit removal tool at Aircraft Spruce. Check out the following:
http://www.aircraftspruce.com/catalo...vetremoval.php
It really does work very nicely too. I have heard that you can also use a spring loaded center punch to put a dent in the middle of the rivit so you can drill them out. I personally have felt that the tool I bought was well worth the money. I had to take out a whole external panel and drilled out maybe 50 rivits without any problems.
Malcolm
malconium is offline   Reply With Quote
Old 10-19-2004, 11:21 PM   #6
greg176's Avatar
Gabriola Island , British Columbia
To get a center on the rivets that do not show a dimple us a center punch.I also use the punch on the rivets with a dimple to get a good center for the drill.
greg176 is offline   Reply With Quote
Body and banana wrap on floor replacement technique. malconium Repairing/Replacing Floor &/or Frame 56 09-09-2005 10:09 PM
Reattaching banana wraps? Mike B Belly Pans & Banana Wraps 2 05-10-2004 05:44 AM
Banana Wrap Finish trogers713 Belly Pans & Banana Wraps 6 10-29-2003 03:26 PM
Banana Wrap trogers713 Belly Pans & Banana Wraps 1 10-27-2003 06:36 PM
