Old 02-11-2016, 09:08 AM   #29
Atomic_13's Avatar
1968 24' Tradewind
1968 26' Overlander
Kansas City , Kansas
Kip - if you were to make new banana wraps what type of aluminum would you suggest using?
My AS renovation: http://www.airforums.com/forums/f116...on-134984.html
Atomic_13 is offline   Reply With Quote
Old 02-11-2016, 05:30 PM   #30
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I'd use 6061-0, it will work harden the more it's worked so it may have to be annealed a couple of times. A good English Wheel would help too.
Old 02-11-2016, 08:36 PM   #31
1968 26' Overlander
Manheim , Pennsylvania
Not too bad for using just my bare hands!!
Well... And some help from cave man tools. Kip, you were right. The metal is very maluable. This is the street side banana wrap from my last picture after banging on it for a few hours with a small rubber/plastic mallet and a wooden block I gig sawed to the same shape of an outrigger. Also used the back side of a rubber sanding block and pounded it on the backside with the front up against a gallon ziplock bag full of lentils. Saw that somewhere here on the forums. Worked pretty well!
If I had access to an English wheel, I'd run this one through a few times to get the little bumps out, but to be honest... It's way better than it was, and that's good enough for me!
The other one will definitely need a patch job! Click image for larger version
SonOfAnder
'68 Overlander
http://www.airforums.com/forums/f44/...te-145553.html
SonOfAnder is offline   Reply With Quote
Old 02-11-2016, 10:19 PM   #32
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
That's pretty darn near good! Wow that looks awesome compared to what it use to look like
Matt
rugjenkins is online now   Reply With Quote
Least expensive repair thenewkid64 General Repair Forum 5 09-23-2013 08:49 AM
Alum. Skin Repair 74Tradewind Ribs, Skins & Rivets 12 10-31-2009 01:30 AM
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 08:28 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
airstream repair halloey General Interior Topics 3 07-27-2002 06:48 PM
