Old 02-20-2012, 06:00 AM   #1
Frankiefiveo's Avatar
1966 26' Overlander
Weeki Wachee , Florida
Aluminum Sheets
Can anyone offer me advice on where I would purchase sheets of aluminum to do some work on the under carriage? I have a section that needs to be replaced but I have not been able to find sheets bigger than 12" x 24" and I will probably need 10' x 12'.
Frank
Frankiefiveo is offline   Reply With Quote
Old 02-20-2012, 06:07 AM   #2
wasagachris's Avatar
1973 31' Excella 500
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
Send a message via Skype™ to wasagachris
Any Airstream dealer can get you the belly pan material in the correct width which if IIRC is 65 inches. You can order any length you like.
I ordered mine from Inland RV in California. They are experts in vintage Airstreams and have many items not available from other dealers.
Inland RV Center - The Nations Leading Expert in Airstream Innovations
1973 Excella 500 31ft Center Bath
1963 Overlander 26 ft
1961 Sovereign 30 ft Custom
1955 Overlander 26 ft
1947 Liner 22 ft.
2010 Ford F450 Crew Cab Dually Diesel
TAC ON-11
Every day is a gift, but does it always have to be a pair of socks.
wasagachris is offline   Reply With Quote
Old 02-20-2012, 06:12 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Being on the East Coast (sort of) I would check around. There are several AS dealers on this coast that ship too. Out of Doors Mart in NC is one I buy from pretty regularly. I would also check out aircraft suppliers as well as any metal supply houses you can find. There is one in Mobile, AL but the name escapes me at the moment.
Aaron
WBCCI #XXXX AIR #2495
Old 02-20-2012, 06:14 AM   #4
SummitAir's Avatar
1970 27' Overlander
Summit , Mississippi
Your local or nearby sheet metal company that does roofing and duct work. That is where i get mine.
SummitAir is offline   Reply With Quote
Old 02-20-2012, 07:32 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1998 30' Limited
1947 22' Liner
Valley View , Texas
Images: 47
SummitAir has it right. Go to that local sheet metal (heating/air conditioning) shop. That way you get the metal without shipping costs if it comes, as it should, in with their next delivery. If you use mill finish for the belly its a lot cheaper too.
Old 02-20-2012, 09:21 AM   #6
Maniacal Engineer
barts's Avatar
Menlo Park , California
I've found a "local" metal dealer that recycles, carries new steel and "scrap" aluminum, stainless, brass/bronze, etc. I've often found large sheets there (4'x8', 4'x10') but it is potluck. The nice part is the price - $2.00/lb.
They often have aluminum moldings, angle, etc. which have come in very handy for making custom brackets, wall fasteners, etc. in the Tin Pickle.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 02-20-2012, 10:44 AM   #7
TAC AB-2
truckasaurus's Avatar
1960 33' Custom
Airdrie , Alberta
Truck and trailer guys will also have utility grade on a roll and it's, I think, 100+ inches wide and any length.
truckasaurus is offline   Reply With Quote
Old 02-21-2012, 07:19 AM   #8
1966 26' Overlander
Thank you all for the great responses. I will check with local sheet metal guys first.
Frank
Old 03-14-2012, 02:01 AM   #9
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
What thickness do we need for the belly pan?
Is there a specific "grade" or type of aluminum that is used for the belly pan?
I will be removing the rear quarter panels and want to cut a 12 inch hole through the inner skin of my 1976. What thickness and grade of aluminum sheet do I need to repair the inner skin that I cut through?
Eagle & Bear is offline   Reply With Quote
Aluminum compatible clear coat, where to get? perryg114 Clearcoat, Exterior Paint & Trim 2 03-31-2012 11:26 AM
Aluminum blinds for International CCD 05 amathis55 Upholstery, Blinds, Walls & Interior Finishes 3 02-18-2012 09:51 PM
Aluminum vs Steel Roof Truss masseyfarm Classic Motorhomes 15 02-16-2012 09:18 PM
Centramatics didn't fit my 1980 Airstream with aluminum wheels Nuvite-F Tires 4 02-03-2012 10:09 AM
2008 Airstream Excella 1000 Classic 35ft Aluminum Travel Trailer eBay Watch Airstreams on eBay 1 01-25-2012 09:08 PM
