Old 05-27-2007, 01:35 PM   #1
panabax's Avatar
1984 34' Limited
Dallas , Texas
Advice on Replacing Corner Banana Piece
Below is a picture of the rear of my 34' Limited. I am replacing the piece that transitions from the bannana wrap to the bumper. There is also a picture of the new piece. Obviously, I need to trim the new piece and I can use the old piece as a template. However, I am curious about installation. If you look at the very front of the piece, a tab, about 4" wide, its bent up to go behind the rub rail and get riveted into the side of the trailer. At the rear, the top is riveted to the top of the frame rail. However, how do I attach the rest of the top? The one I took off was just held in place by the rivets in front and at the rear, plus several underneath. It seems like there should be some way to attach the top of this piece to the bottom of the trailer. Also, the front tab had propogated a small tear in the one I took off. Is this really the way AS originally installed this piece?
I hope all that made sense.
Thanks.
Baxter
Whoever said
"it's not whether you win or lose"
probably lost!
panabax is offline   Reply With Quote
need advice re. 1969 tires, brakes, etc. Dave Cole Tires 6 01-29-2007 06:04 AM
Advice for long term trailering Cheryl Full-Timing 49 07-29-2004 01:58 PM
Replacing my 64 Globetrotter Floor BobbyW Repairing/Replacing Floor &/or Frame 4 06-28-2002 11:28 AM
Advice please - Travels, Flags, Fuel and Caravans NickSowter On The Road... 6 06-27-2002 10:04 AM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
