Old 01-16-2018, 05:40 PM   #1
1989 29' Excella
Emeryville , California
Advice for bellypan
Hello all!
My husband and I have just purchased our first Airstream! A 1989 Excella.
Since we have never owned one of these beauties before, we are looking for a little advice. Underneath the front of the Airstream, right behind the lip, there is some exposed wood (see photograph). The previous owner hadn't realized there was exposed wood - I am guessing its the wood of the subfloor.
If possible, I would love advice - what should I do? My initial inclination is to cover the area with a piece of aluminum, but I would rather ask advice before doing anything.
Thank you all in advance!
Sarah and Derek
Murphy_01 is offline   Reply With Quote
Old 01-16-2018, 06:32 PM   #2
1977 31' Sovereign
Sunset Valley , Texas
I’d seal it (it looks to be OSB which would be correct for the year) and slap some aluminum over it. You can get aluminum stock at Lowe’s Depot. Before you secure it, run a bead of trempro (vintage trailer supply) around the backside of your scab piece. You will only need a couple (short) screws to secure it.
Iansk is offline   Reply With Quote
Old 01-16-2018, 06:38 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
It looks like someone already added a strip of aluminum and caulk. I would continue that same procedure on all of the exposed wood.
Be extremely carful that the screws are short so that they do not penetrate the flooring above.
Alan
Old 01-17-2018, 09:06 PM   #4
1989 29' Excella
Thank you both for your replies! We will report back when completed.
- Sarah and Derek
Bellypan Questions for the Experts - Need Advice dbj216 Belly Pans & Banana Wraps 13 07-01-2009 09:01 AM
Bellypan Rivet Repair 66Overlander Belly Pans & Banana Wraps 19 09-15-2004 03:58 PM
BellyPan and Wheel Well Caulking/Sealer mbatm01 Belly Pans & Banana Wraps 2 09-07-2004 07:19 PM
Water in Bellypan? Waterman Belly Pans & Banana Wraps 6 12-07-2003 10:41 PM
Bellypan Rivet Question Creampuff Our Community 7 01-22-2003 07:42 PM
