Old 02-21-2010, 09:49 AM   #1
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Question Acess Panels in Belly Pan
Has anyone thought of placing access panels in strategic places in the belly pan? I would like to have access to the under floor area and frame for installing new wires , etc. I was thinking maybe something with stainless steel Dzus fasteners. Any ideas?
Regards,
Ken
Old 02-21-2010, 09:52 AM   #2
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
I thought about doing something similar but instead installed the belly pan in sections so that anything flat can be removed without affecting the compound curved sections.
truckasaurus is offline   Reply With Quote
Old 02-21-2010, 10:54 AM   #3
1955 16' Bubble
claremore , Oklahoma
Speaking of access panels,I'm looking for a source of aluminum hinged units with snap locks to secure. Anyone know of a source for built up units that just need riveted in?
walt c is offline   Reply With Quote
Old 02-21-2010, 11:16 AM   #4
fmrcaptevil's Avatar
Weldon Spring , Missouri
My dealer (Bill Thomas in St. Louis), installed access panels beneath the black & gray dump valves, to provide easy access to the sensors, (which unfortunately, go bad quite frequently), at a reasonable price. (Just FYI, the fresh tank sensor in the 25FB is accessed from inside the trailer).
fmrcaptevil is offline   Reply With Quote
Old 02-21-2010, 11:20 AM   #5
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
I sort of have one on the right side of the step as you face the door. Dillons in Apache Junction cut a flap and reattached the flap with a screw after putting a new bolt in the step--under warranty
Since then I have had to unscrew the flap and tighten the bolt twice. I believe I need an access door
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 02-21-2010, 11:25 AM   #6
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
I think another nice place to have one would be under the refrigerator. Every few years you could unbolt the burner and clean it out then reattach (with never-seize and stainless bolts) without pulling the unit out of the interior...
fotochop is offline   Reply With Quote
Old 02-21-2010, 11:31 AM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I needed to get to the dump valve on our Caravel. I found that a PO had needed to get to that area and had installed two removable panels, and had updated the dump valve. They were held in with pop rivets, but a 1/8" bit made short work of them and I was in to make the needed repair.
Sometimes we get lucky.
Thank you PO.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 02-21-2010, 12:32 PM   #8
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
We spent an entire day inspecting our prospective CCD 25 before turning over the correction list to the selling dealer. Somehow it completely escaped us, in our newbie condition, to spend as much time looking under the belly pan and at the back of the wheels.
What would we have found? Broken wire to an electric brake? Poorly attached lines on the belly pan? How about the approx 18" X 18" access panel under the toilet? I haven't needed to open it and only guess maybe they must have been looking for something they lost there. Or repairing a frozen line?
I found it two years later when I happened to look up after repairing a wire to the streetside rear wheel brake.
Anyway, anywhere I need an access panel I'll rivet a flat aluminum piece with 2" lap and butyl or other sealing tape between. Hopefully I can do my repair well enough I won't plan to go back in again.
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Belly Pan Aluminium Streamsaver Belly Pans & Banana Wraps 5 09-08-2014 09:11 AM
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 21 08-29-2010 04:56 PM
Belly pan completely off......???? gutsgolf Belly Pans & Banana Wraps 33 10-28-2009 02:25 AM
Belly pan off or on ? augier Belly Pans & Banana Wraps 6 08-08-2009 02:04 PM
belly pan hlink Belly Pans & Banana Wraps 10 09-16-2008 07:51 AM
