Old 08-26-2007, 08:40 PM   #1
1972 23' Safari
Dearborn , Michigan
72 Safari Removing Banana Wrap in front of battery compartment
I am in the process of fixing the floor under the bathroom and I decided to remove all the belly skin in the back of the trailer. Things were going fairly well until I go to the piece by the battery compartment. I managed to get it off around the battery compartment but then between the battery compartment and the fender well it is put together differently and it won't move.
The aluminum is sort of in the way because there is a bit of damage I need to fix by the battery compartment.
Any suggestions ... Pictures attached
Name:	Banana Wrap Overview.jpg
ID:	43916   Click image for larger version
Name:	Different Overlap.jpg
Tom Bray is offline   Reply With Quote
Old 08-26-2007, 09:48 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Take out enough rivets to peel back the side panel skin a little. You'll find some hidden rivets unde that skin that attaches the bannana skin. Thus, my motto, "NO ^%$&* hidden rivets!!!!"
Old 08-27-2007, 11:55 AM   #3
Radman's Avatar
1972 27' Overlander
Monterey Bay , California
Images: 129
My 72 had hidden screws that had been screwed into the back of the wheel well area. They were also covered in vulkem so they were hard to see. It was a bear to get em out. Good luck.
Radman is offline   Reply With Quote
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 6 02-08-2013 06:34 PM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 04:52 AM
Second Battery w9det 1999 Safari 5 12-06-2002 06:42 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 10:13 AM
