Old 09-22-2015, 08:56 PM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
70's rear corners
So I'm thinking about replacing the pan soon (as part of my renovation). I was planning on just getting the stuff from airpartsinc, 4x12' sheets...fine for the flat sections between the main frame rails. The rear corner areas, outboard of the main frame rails, which span from the frame to the banana wraps...should these be the same material, or should they be alclad?
On my particular model, there isn't much aft of the wheel wells, but there is about a foot on the street side that needs to bend up and around the outriggers, attaching to the exterior wall of the trailer, so this is plainly visible from the side.
I'm wondering, is this original piece clear-coated alclad? It looks like a pretty close match to the rest of the exterior skin on the trailer. even though 90% of this piece of aluminum is the "underneath", facing straight down, and not visible, its all one single piece.
On the curb side, the only visible section that wraps up into the sidewalls is about 6-8" long; the rest of that space is consumed by the battery box. (aft of the box, its all banana wrap.).
So I'm wondering--what material for these pieces? Do people just use the 5055 non-alclad, or is that going to stick out and look funny?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-25-2015, 07:45 AM   #2
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
This piece (and the corresponding one on the other side):
I attached the banana wrap with clecos for clarification.
ID:	248906   Click image for larger version
Air:291
Wbcci: 3752
'73 Safari 23'
Old 09-25-2015, 08:29 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Well, there are a couple of threads running right now that discuss what type of aluminum the shells of AS in the 70's are made of. In '73, there is a good likelihood that your trailer is made of 6061 T6. The crux of the debate on the earlier mentioned threads is whether the Alcladding ended when AS switched over to 6061, or whther it is a 6061 Alclad--nobody seems to know for sure.
So when I redid my bellypan, I used 6061 T6 on a .032 thickness (non-alclad). It was tough (daunting) to make those curves where the pan wraps up to meet the shell. Luckily, I had bought an English Wheel on a whim, and that did the trick. I used 5055 on my interior, and that stuff is soft as butter--I don't think I would want to use it in an application where it might need ding-resistance. Whatever the completely curved banana wraps is made of, it is actually softer than butter. Mine were very dented, dinged, and deformed, but I got them straightened out. Tried to buff them a bit to see if they would take a shine, and concluded that there is no way (which, I think would argue against worrying about using Alclad on the belly skin).
http://www.airforums.com/forums/f441...al-141141.html
good luck!
Shell off floor pattern - rear corners different! Kieffer4 Repairing/Replacing Floor &/or Frame 6 01-06-2012 06:55 PM
4CU 004 : Four Corners Unit Rally azflycaster WBCCI Rallies & Events 658 11-20-2007 07:47 PM
Four Corners Unit guidebook recommendation 47WeeWind Off Topic Forum 2 10-11-2006 05:19 PM
Heading for the 4 Corners! dscluchfc On The Road... 19 08-08-2006 01:27 AM
belly pan corners tonyg Belly Pans & Banana Wraps 0 09-21-2003 05:14 PM
