Old 05-18-2004, 08:50 PM   #1
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
65 Caravel belly
On my 65 Caravel, before I move it, I need to reattach the belly pan. What rivets should I use? Thanks,
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 05-19-2004, 12:28 AM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Check out~
Rob
Greetings Rob~
Geez, I did this same thing several years ago, and don't recall the actual part number. If you go by 'Home Depot' tools section, you will see rivets.
What I recall using was something rather large. Like maybe a 5/16 drill bits in diameter, and at least 1/2 inch long. ?? Not just real sure..
I used this size as I was re-attaching the belly skin to the frame as well.
When you're there looking over the inventory..It should leap out at you which one looks abt right.
Otherwise, you could try sending Andy (Inlandrv) an e-mail for a better reply..
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
caravel
Another happy Caravel owner rluhr 1966-68 Caravel 110 07-04-2007 03:04 PM
where belly meets floor meets shell JrnymnJay Repairing/Replacing Floor &/or Frame 6 01-09-2006 12:05 PM
Water in the belly pan?!?!??? Safari Tim Leaks - Weatherstrips, Gaskets, Caulks & Sealants 22 04-28-2004 01:45 PM
