Old 11-28-2010, 10:00 AM   #1
1957 26' Overlander
Raleigh , North Carolina
'57 overlander belly pans
Does anyone have advice for re-making the belly pans on the ends of a '57 Overlander? They are strangely shaped, and I'm not sure how to get a flat sheet of aluminum (such as from airparts inc.) to bend around the corners and look original.
movinair is offline   Reply With Quote
Old 11-28-2010, 10:24 AM   #2
pbearsailor's Avatar
Port Hadlock , Washington
They were a pain in the .......
I used 5052 .025 for the ends and .032 for the middle. Once you get the old off, you'll hopefully have a decent template to work with. Mine aren't perfect, but they are done. Just need to take time and have patience and after a month or so they'll be back on.
-steve
BTW, if you're going to document your resto here, and we hope you do, start up one thread for it and you'll have a bunch of people following your work. Easy to keep track of it that way.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Rear pans-Storage tanks la4photo 1974 - 1979 Sovereign 4 06-18-2010 09:14 PM
5 year old 16 Bambi with Rotten Belly Pans bren_vt2002 Belly Pans & Banana Wraps 2 10-24-2009 06:28 PM
What is Advantage of Belly Pans? TankerIP Belly Pans & Banana Wraps 3 09-04-2009 06:54 PM
Belly Pans - 1965 1965GT 1965 - 1969 Globetrotter 1 09-20-2006 04:21 PM
Air Conditioner pans Inland RV Center, In Commercial Listings 9 04-30-2003 06:46 PM
