Old 03-23-2006, 07:21 PM   #1
2toomany's Avatar
1973 23' Safari
1963 19' Globetrotter
Forest , Mississippi
Yikes!!!!!
Just stop by my local ex-airstream dealer to pick up a couple of bolts to fix an entry step for my airstream. 2 complete shoulder bolts and 2 complete socket bolts, I think that's what there are called. Anyone what to guess how much, I would have never guessed.
How about 50 bucks, did I just get taken???
Well for better or worse I sure hope that finishes up my step project
Does anyone know of any other sources if I should need other small step parts?
2toomany is offline   Reply With Quote
Old 03-23-2006, 07:47 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Sounds about right...those parts are EXPENSIVE a complete step assembly runs in the $750 range IIRC.
Aaron
WBCCI #XXXX AIR #2495
Old 03-23-2006, 08:01 PM   #3
Elgin , Texas
Images: 164
Yep, they aren't cheap - and they're just unique enough that it's virtually impossible to find alternatives.
bake315 is offline   Reply With Quote
Old 03-24-2006, 07:51 AM   #4
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Which bolts are these?
Do they connect the side arms to the step? My second step has busted at the side arm/step connection (looks like some sort of huge rivet?)
Thanks!
Marc
SAFETY : >>>>Lightning Strikes<<<< hex Our Community 36 12-18-2005 11:34 AM
Yikes! What is it? Chaplain Kent Exterior Restoration Forum 6 06-05-2005 01:41 PM
SMOKE! Yikes!! Help! SilverToy Interior Restoration Forum 26 04-01-2005 09:50 AM
Airstream trailer weights FrankR Link Archive 11 10-17-2003 07:09 AM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
