Old 06-11-2011, 04:07 PM   #1
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Yep, it's THOSE steps
So I have a problem. Steps wigged out on me today. Basically, the opening in the outrigger on the right side of the steps finally got so worn that they won' stay locked in place. Left side looks like the day it left the factory. Right side is so worn that they won't deploy and stay locked at all. A couple of pics.
www.nesa.org
Air No. 6427
Old 06-11-2011, 04:09 PM   #2
Got gandkids?
Pic 1
www.nesa.org
Air No. 6427
Old 06-11-2011, 04:11 PM   #3
Got gandkids?
This shows the left side, looks factory new. Step easily locks into place with no problem.
www.nesa.org
Air No. 6427
Old 06-11-2011, 04:13 PM   #4
Got gandkids?
This is the right side. Won't lock in place any longer because the steel has worn down over the years.
www.nesa.org
Air No. 6427
Old 06-11-2011, 04:18 PM   #5
Got gandkids?
For those of you that have dealt with this issue before, you'll notice that the right side is worn and rounded, no place for the bolt on that side to settle into.
So do I grind down both sides to an identical, symmetrical design (preferred choice), or have a welder add a spot of weld in there and shape to fit the other side (read: grind away and hope I get it right )
As always, thanks for the ideas gang.
www.nesa.org
Air No. 6427
Old 06-11-2011, 04:23 PM   #6
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
I am no metal-worker by any stretch...could you scab a piece of metal in the proper shape on either side of the bad outrigger? ...or something to that effect. Just a thought...
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 06-11-2011, 04:23 PM   #7
Ottawa , ON
Do you think JB Weld is tough enough for something like that?
Old 06-11-2011, 04:26 PM   #8
Maniacal Engineer
barts's Avatar
Menlo Park , California
When I repaired ours I used a MIG welder, round file and carbide burr in a die grinder - not a very difficult repair. The slots need to be similar, but by most metal working standards there's plenty of tolerance for differences.
Our right side wore down as well... I made 'em match w/ the welder. Note that you can easily trace the good side and use that to match up the other side.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 06-11-2011, 04:28 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It can be made to work again
I had the same problem. Just took a rat tail file and made the notches deeper. It took a while to file new notches. Not much working room. I studied it for a while to try and determine which way and how deep, but it worked out. Now I can pull the release lever and the steps swing down and lock into place. It might be easier if you could get a rotary rasp; about 3/8" diameter and put it in a drill motor.
Old 06-11-2011, 04:29 PM   #10
Maniacal Engineer
barts's Avatar
I'd be very surprised if JB weld would work here - the built up area is small, and the load quite high - which is why the steel wears out over time.
- Bart
Bart Smaalders
Menlo Park, CA
Old 06-11-2011, 04:31 PM   #11
Lothlorian's Avatar
Loganville , Georgia
Jim:
I don't even use mine. I made wooden steps and carry them in the truck. Adrienne does not like the airstream step and the dogs struggle with it. I really like the wood steps because they are more comfortable going up into the trailer. I stained them and put out door carpeting on them. I have two sets of steps. One I keep in Illinois and the other I use around here.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 06-11-2011, 05:01 PM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would file in this direction. Just enough where the pin on the step sets in good and solid.
Old 06-11-2011, 05:07 PM   #13
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I saw this solution at the first Branson rally almost four years ago now.
http://www.airforums.com/forums/atta...4&d=1192908130
The top has a T sweated on and the bottom has one with a slot to fit over the back of the step. There are one on each side, it's kind of hard to see the one on the left because of the shadow. They hold the step out in positions without depending on the notches in the side.
Clever and cheap. The steps were nice and solid.
Vaughan
Old 06-11-2011, 05:27 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
What is the top T attached to?
'70 Overlander Steps: step 2? rayandre Steps 10 10-04-2012 08:42 AM
Old air conditioner removed... Steps for new installation Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-14-2011 03:25 AM
'64 safari steps repair question Homewrecker Steps 4 03-14-2011 03:01 AM
1975 Trade Wind Steps missing. Breadbug Steps 0 02-16-2011 10:22 AM
Sealing steps thread or photo? LawChick General Repair Forum 2 02-14-2011 06:40 PM
