Old 06-11-2011, 05:41 PM   #15
Fairway
Fairway's Avatar
1986 34' Excella
1996 34' Excella
Shavertown , Pennsylvania
Thumbs up
I'd probably go with Twinkies reccomendation, but I'd replace the rasp with my Dremel tool and a rotary grinding bit
good luck
Fairway is offline   Reply With Quote
Old 06-11-2011, 05:50 PM   #16
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Originally Posted by barts View Post
When I repaired ours I used a MIG welder, round file and carbide burr in a die grinder - not a very difficult repair. The slots need to be similar, but by most metal working standards there's plenty of tolerance for differences.
Our right side wore down as well... I made 'em match w/ the welder. Note that you can easily trace the good side and use that to match up the other side.
- Bart
That's what I was thinking I would do as I read thru this thread - I doubt
JB weld would last long in this application.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 06-11-2011, 06:02 PM   #17
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
The right side of mine was also bad. Plus, the lower step no longer would hang parallel to the ground and was tilting forward significantly. and, the steel band iron accross the top of the assembly had failed making the step even more spongy. I coughed up $650 for a new step and welding of all the new components.
4RXLA is offline   Reply With Quote
Old 06-11-2011, 06:59 PM   #18
2010 25' FB Flying Cloud
Davenport , Iowa
BE CAREFUL, when the steps broke on my 98 AS, it cost me $60K. I went to order the parts and my wife started talking to the salesman before it was over we had a 2010 AS.
Airtandem is online now   Reply With Quote
Old 06-11-2011, 08:12 PM   #19
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by TG Twinkie View Post
What is the top T attached to?
It doesn't really attach to anything. I tucks into the 90 degree corner formed by the back and top of the compartment that holds the steps. When they are the correct length, you slip them onto the back of the bottom step while raising it a little. When the step is lowered to the correct position, it moves inward pushing the top into the (upper) corner. Easy!
Vaughan
Old 06-12-2011, 05:48 PM   #20
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Thanks for the tips & hints, boys. I took a tape measure to it today and noticed that the factory cutout (left side) is about 1/8" further from the top of the outrigger than the worn side (right side). My guess is that the two sides need to be about the same distance from the top of of the outrigger to bring things to a sort of level, so I'll grind away on both sides until there's some symmetry there. Suspect that this will leave the step slightly off-level, but that's probably agreeable. I'll post back with measurements and results as I get the work done.
Brian, Susan found a step like you're describing on-line someplace. She just wants to buy one of those and let the steps be an unused cosmetic feature. I, on the other hand, see this as an opportunity to crank up the power tools and "fix something". I guess it's just a guy thing. Never pass up an opportunity to fire up a new tool....
www.nesa.org
Air No. 6427
Old 06-13-2011, 06:21 AM   #21
Lothlorian's Avatar
Loganville , Georgia
I got both of my steps from guys putting pre-made steps in. They cut off a few steps to make it fit and gave me the left overs. Home Depot is the place.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 06-13-2011, 06:35 AM   #22
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I have one larger one of those braces, and it goes in the center of the step, rather than 2 small ones on the outside. I'm sure the 2 smaller ones are more stable. But anyway, I think this is just to support the lower step; I don't think it'll do much to support a wobbly top step.
Replacement outriggers are surprisingly inexpensive...but the job of replacing them is quite involved, what with all that has to be dis-assembled in order to get at them.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-18-2011, 07:33 PM   #23
Got gandkids?
Looks like you guys got it exactly right, And thanks again for the tips. I simply put a de-burr tool on the drill and shaped things up. The right (worn) side needed cleaning up with the tool. Then I had to grind about 1/8" out of the top of the left side (factory original, not worn at all). Everything locks into place just fine now. This forum is a great place for info!
Thanks guys.
www.nesa.org
Air No. 6427
'70 Overlander Steps: step 2? rayandre Steps 10 10-04-2012 08:42 AM
Old air conditioner removed... Steps for new installation Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-14-2011 03:25 AM
'64 safari steps repair question Homewrecker Steps 4 03-14-2011 03:01 AM
1975 Trade Wind Steps missing. Breadbug Steps 0 02-16-2011 10:22 AM
Sealing steps thread or photo? LawChick General Repair Forum 2 02-14-2011 06:40 PM
