Old 12-02-2015, 04:04 PM   #1
MontyV's Avatar
1994 34' Limited
Salem , Oregon
Where to find AS step parts
one of the screws that hold the folding steps together vibrated out going down the road. AS dealer says they don't carry such parts. where can i get one of these screw and cap nut sets?
MontyV is offline   Reply With Quote
Old 12-02-2015, 04:11 PM   #2
Gainesville , Florida
Possibly a hardware store.
Old 12-02-2015, 04:16 PM   #3
2007 22' International CCD
Check with Inland RV. They probably have it.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 12-02-2015, 04:25 PM   #4
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I have talked with the tech people at Jackson Centre and successfully ordered parts direct, but my understanding is that generally they want you to go through a local authorized dealer to order parts for you - I'm surprised your dealer would not do that.
I believe that the screws for the steps are specialty items and I think there are several sizes used in one set of steps. I'm sure someplace I have seen diagrams with part numbers for all the different screws.
I doubt you'd have much luck at a hardware store in this instance.
You might tray calling JC and possibly they would email you an assembly diagram of the steps so you can be sure you are ordering the correct screws.
Good luck - Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-02-2015, 04:36 PM   #5
1994 34' Excella
Warren , Manitoba
Out of Doors Mart has the parts as well as the parts breakdown. Try their site for parts. They are an Airstream dealer as well. Good luck. Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 12-03-2015, 10:53 AM   #6
1977 25' Tradewind
Cibolo , Texas
I had the same problem and my AS dealer ordered the part and fixed it but it cost me an arm and a leg. Maybe because they put in a new door lock also.
GailMac is offline   Reply With Quote
Old 12-03-2015, 11:41 AM   #7
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Responding on my phone so don't know your location. If in TX, I call the factory for the part #, and then Camper Clinic II in Austin / Buda.
banderabob is offline   Reply With Quote
Old 12-03-2015, 11:58 AM   #8
1996 25' Excella
Tillsonburg , Ontario
I lost one while on the road last year. Replaced it with a screw from a hardware store. Originals are hex socket heads. My replacement was square drive (Canadian eh!)
JCW
JCWDCW is offline   Reply With Quote
Old 12-03-2015, 12:04 PM   #9
Sarasota , Florida
Try Vintage Trailer Supply saw the parts there
Less than Airstream
Not cheap. part
Specific to application
DavidSowder is offline   Reply With Quote
Old 12-03-2015, 01:31 PM   #10
1972 31' Sovereign
Huntley , Montana
Airstream parts
I bought a 1972 31' Sovereign several years ago. Although it had two steps, the bottom step was not attached. I found the right screws at Inland RV. Because they are specialty screws, they cost more than one might think.
Philip498 is offline   Reply With Quote
Old 12-03-2015, 01:49 PM   #11
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
This is definitely a hardware store solution. Bring an example of what you want to get with you (hopefully you still have a matching screw in your step mechanism that you can borrow.)
Bob Martel
WBCCI# 5766
Old 12-03-2015, 06:09 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
There are some special screws on our 1999 step. the length, tapered head, shims, was washers... all special and I never found at the Big Box stores.. a REAL hardware store.. well, perhaps..
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-03-2015, 08:13 PM   #13
1972 31' Sovereign
Huntley , Montana
AS parts
I agree with CWF. The screws on my 1972 Sovereign had tapered heads, shims, etc. that I don't think I would find in a hardware store. And when I say they are more expensive than one might think, I mean about $30 each if my memory serves me correctly!
Old 12-03-2015, 08:31 PM   #14
1994 34' Limited
Round Rock , Texas
I just went through this exercise a few weeks ago. It was $80 for the 3 screws I needed. The PO tried to use a standard bolt to fix the issue and actually damaged the steps, so I had to do some work to make them fit together correctly. Out of Doors Mart has the parts, and they ship out quickly.
txtwin is offline   Reply With Quote
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 07:49 PM
Step-by-step sewing an awning yukionna Awnings 11 12-28-2006 01:37 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
