12-02-2015, 04:04 PM
1994 34' Limited
Salem
, Oregon
Where to find AS step parts
one of the screws that hold the folding steps together vibrated out going down the road. AS dealer says they don't carry such parts. where can i get one of these screw and cap nut sets?
12-02-2015, 04:11 PM
Mantua
, Ohio
Possibly a hardware store.
12-02-2015, 04:16 PM
2007 22' International CCD
Corona
Check with Inland RV. They probably have it.
12-02-2015, 04:25 PM
2005 30' Classic
Burlington
, Ontario
I have talked with the tech people at Jackson Centre and successfully ordered parts direct, but my understanding is that generally they want you to go through a local authorized dealer to order parts for you - I'm surprised your dealer would not do that.
I believe that the screws for the steps are specialty items and I think there are several sizes used in one set of steps. I'm sure someplace I have seen diagrams with part numbers for all the different screws.
I doubt you'd have much luck at a hardware store in this instance.
You might tray calling JC and possibly they would email you an assembly diagram of the steps so you can be sure you are ordering the correct screws.
Good luck - Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
12-02-2015, 04:36 PM
1994 34' Excella
Warren
, Manitoba
Out of Doors Mart has the parts as well as the parts breakdown. Try their site for parts. They are an Airstream dealer as well. Good luck. Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
12-03-2015, 10:53 AM
1977 25' Tradewind
Cibolo
I had the same problem and my AS dealer ordered the part and fixed it but it cost me an arm and a leg. Maybe because they put in a new door lock also.
12-03-2015, 11:41 AM
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera
Responding on my phone so don't know your location. If in TX, I call the factory for the part #, and then Camper Clinic II in Austin / Buda.
12-03-2015, 11:58 AM
2012 23' FB International
Woodstock
, Ontario
I lost one while on the road last year. Replaced it with a screw from a hardware store. Originals are hex socket heads. My replacement was square drive (Canadian eh!)
JCW
12-03-2015, 12:04 PM
2000 30' Excella
Sarasota
Try Vintage Trailer Supply saw the parts there
Less than Airstream
Not cheap. part
Specific to application
12-03-2015, 01:31 PM
Airstream parts
I bought a 1972 31' Sovereign several years ago. Although it had two steps, the bottom step was not attached. I found the right screws at Inland RV. Because they are specialty screws, they cost more than one might think.
12-03-2015, 01:49 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
This is definitely a hardware store solution. Bring an example of what you want to get with you (hopefully you still have a matching screw in your step mechanism that you can borrow.)
Bob Martel
WBCCI# 5766
12-03-2015, 06:09 PM
1999 34' Excella
Hillsboro
There are some special screws on our 1999 step. the length, tapered head, shims, was washers... all special and I never found at the Big Box stores.. a REAL hardware store.. well, perhaps..
Peace and Blessings..
Channing
WBCCI# 30676
12-03-2015, 08:13 PM
AS parts
I agree with CWF. The screws on my 1972 Sovereign had tapered heads, shims, etc. that I don't think I would find in a hardware store. And when I say they are more expensive than one might think, I mean about $30 each if my memory serves me correctly!
12-03-2015, 08:31 PM
1994 34' Limited
Round Rock
I just went through this exercise a few weeks ago. It was $80 for the 3 screws I needed. The PO tried to use a standard bolt to fix the issue and actually damaged the steps, so I had to do some work to make them fit together correctly. Out of Doors Mart has the parts, and they ship out quickly.
12-03-2015, 08:33 PM
2003 31' Classic
Terra Alta
, West Virginia
If it's one that runs through the trailer frame, I found mine . In the body metal below...the banana wrap? The step broke while camping in Charleston SC. Thought it was good luck but now that I heard how valuable they are, I will be sure to check tightness now and then. Had to use a small magnet stick to get it out with some metal trimming but put it back and all is good. You might look for it.
