Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 10-28-2007, 10:30 AM   #15
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Replacement Steps
Originally Posted by byamcaravanner
Elkhart Tool makes a unit for total replacement. Check out unit #424
Hi Steve,
Thanks for the link. I didn’t see anything at ETD that looked like the steps on my Airstream, though. I would rather repair mine or even just use the braces than adapt what I saw there.
I do appreciate the effort.
Vaughan
Old 10-28-2007, 12:48 PM   #16
byamcaravanner
byamcaravanner's Avatar
Profile:  1967 28' Ambassador
1963 19' Globetrotter
Waukesha , Wisconsin
Originally Posted by vswingfield
Hi Steve,
I agree that they aren't the same...actually the slides are just opposite of the original...but they are the only aftermarket steps that achieve the flush look when closed.
My plan is to repair the original unit already installed on mine.
Good luck finding a solution that works for you.
Steve & the crew
'67 Ambassador International Twin
'63 19' Globetrotter
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 11-11-2007, 07:37 PM   #17
bilby05
bilby05's Avatar
Profile:  1969 31' Sovereign
Canyon , Texas
Airstream double steps
Airstreams double aluminum footstep will fit your 69, but you must change the footstep outriggers and add a release bracket at the bottom of the entrance door.
Andy,
A couple of questions. About how much would the double steps cost? and the installation procedure doesn't sound like a do it yourself job, correct?
thanks, bill b.
bill b.
1969 Airstream Sovereign 31'
2001 F250 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 11-11-2007, 08:58 PM   #18
Commercial Vendor
Profile:  Corona , California
Originally Posted by bilby05
Andy,
thanks, bill b.
If you can rivet and weld, it's a piece of cake.
The double aluminum footsteps with the release latch, anti-skid pads and two outriggers cost way over $500.00.
I am not at the office, so I cannot accurately quote.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 11-11-2007, 09:10 PM   #19
wingfoot321
Profile:  1987 29' Sovereign
Sparta , Tennessee
Word of Warning
If you have the double steps, do not use them without some type of brace to take the force off of the system. I have the brace made by an airstreamer and usually used it whenever we would think about it. It was a sloppy fit and there was a little movement which would cause a slight jerking motion as you put full weight on it. Bottom line, didn't use it for a couple years and now one of my side brackets has rounded out and it is not a simple job to repair.
I plan to take the trailer to a good welder and have him build up the track just as Andy suggests. Then it will be a matter of filing the curve back into the track so it will hold.
These steps can be dangerous if you are not aware.
wingfoot321 is offline   Reply With Quote
I put something in my oil? ArtStream Tow Vehicles 4 10-24-2007 12:22 PM
Where should one put a stereo? gergstuff All Argosy Trailers 11 06-14-2007 07:09 PM
Put me in a harness... bevman Batteries, Univolts, Converters & Inverters 10 04-02-2007 02:03 PM
Wasnt for sure of where to put this.... Angel73 General Interior Topics 15 05-05-2006 08:31 PM
And Now to put it back together. 59toaster Cabinets, Counter Tops & Furnishings 50 10-23-2005 07:56 AM
