Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 09-14-2009, 10:09 PM   #1
Profile:  1969 27' Overlander
Lehi , Utah
steps rusted out?
It must have had a bad leak for a long time and now the steps are shot. Has anyone replaced them? I am guessing I will need to do some frame work and the floor needs to be replaced, but the steps are my major concern.
Clay C
ClayC is offline   Reply With Quote
Old 09-15-2009, 06:31 AM   #2
DEITZ645's Avatar
Profile:  2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 99
Clay,
You may be able to find replacements steps and parts at Out Of Doors Mart or Inland RV. I got new step parts for our '87 from Out Of Doors Mart, but I am not real familiar with the steps on your Overlander. I do know they both will have the frame outriggers that you may need.
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package Katarina
1987 34' Excella 1000 Double Door Savannah
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
AIR #14487
WBCCI #7429
DEITZ645 is offline   Reply With Quote
Old 09-15-2009, 06:48 AM   #3
Profile:  1968 24' Tradewind
Oxford, , Mississippi
You will need a skilled welder. Some fabrication will be needed. Shouldn't cost too much if you look around. Lots of welding shops are not really busy because of the economy. I would take the floor out first, fix the step, then replace the floor. Much easier to do the frame repair if the wood is out. I had floor rot at the door of my 68 Trade Wind, it is common on this vintage AS. There are numerous threads on how to replace the floor. I suggest buying a couple of bags of the self tapping floor bolts from Vintage Tailer supply before you start your install.
Old 09-15-2009, 11:43 AM   #4
Lehi , Utah
Hey, Thanks. The floor out makes a lot of sense, It has to come out anyway. in the mean time I will call out of Doors Mart or vintage and see what replacing them takes. Were there ever electric steps on AS?
Clay C
Old 09-15-2009, 12:01 PM   #5
DEITZ645's Avatar
1987 34' Excella
Images: 99
Clay C
I think only on the motohomes, but there's always a first time for everything.
AIR #14487
WBCCI #7429
Old 09-16-2009, 09:43 AM   #6
Lehi , Utah
I have a switch/button by our sink that I can't figure out. I thought it may be for the steps. Clay C
Step slide rusted out Odessa-Don Steps 3 05-31-2009 03:46 PM
Rusted tight hampstead38 1967 Overlander 14 08-27-2008 01:09 PM
Steps Rusted Shut and Stuck kneal Steps 3 12-04-2006 02:12 PM
Rusted Rivets luckydc 1999 - 2004 Bambi 6 04-01-2005 11:16 AM
Hitch/Frame Rusted Out airdreamer Repairing/Replacing Floor &/or Frame 13 05-07-2004 12:39 AM
