Old 08-25-2019, 09:51 PM   #1
2018 23' International
SEATTLE , Washington
Steps not properly supported in the extended position
We have a 2018 23' International Serenity. Our steps failed and I need to figure out a repair, as we are on a long trip.
Not certain of the correct terms, but in the retracted position, there is an arm on both the forward and rear sides of the steps that extends up and back toward the upper rear corners of the step enclosure. The rear arm has a bolt that passes through it near its end, extending past the inside surface of the arm (see the first picture ... the threads can be seen). The forward arm has a hole for the bolt, but the bolt is missing (see the second picture). When the steps are in their extended position, the rear side of the steps locks in place, but the forward side doesn't due to the missing bolt (see the third picture). If the bolt was in place, it would guide the steps as it moves down the slot, then come to rest in the anchor position.
I suspect the bolt was not properly tightened during assembly, loosened during use, then fell back through the slot into an area that is fully enclosed by aluminum. Recovering the bolt would mean loosening/removing a small aluminum sheet just forward of the steps.
Any way to repair this while on the road?
ID:	350486   Click image for larger version
chrisnancy is offline   Reply With Quote
Old 08-26-2019, 04:19 AM   #2
Gainesville , Florida
Can you just put a bolt and nut in it?
Old 08-26-2019, 04:31 AM   #3
2019 30' International
Pennsylvania , Pennsylvania
I'd call Airstream in Jackson Center and ask them how to remedy, or see if there's a local rv repair shop that would be able to do the fix.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 08-26-2019, 04:47 AM   #4
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
We went to JC and had our step repaired. However we do not use the step much after buying this portable entry step as a temporary replacement until fixed. The step has a deep first step which makes exiting the AS much easier. Easy to lift and really solid.
The step fits nicely in the entrance when traveling. Never leave without this step. Only bring down the AS step to clean/lube.
Here is a link to the step:
https://www.amazon.com/High-Country-...ateway&sr=8-33
Stay Calm and Stream On!
HHPJ is offline   Reply With Quote
Old 08-26-2019, 05:37 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
What I did....used g5 bolt.
When we got home I took it out, screwed a nut down to the shoulder, ground the threads off where it contacts the notch to minimize ware at that point. Removed the nut, applied Loctite blue and re-installed. 8yrs SFSG 👍
I also filed the notch to better fit the bolt.
POI...it was also 8yrs ago that checking the steps and tightening and lubing the pivots became part of the regular maintenance schedule.🥴
ID:	350511   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 08-26-2019, 10:03 AM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Most (but not all as pointed out above) of the bolts on the step are very custom items. They also aren't very inexpensive. They do fall out / need to be checked for tightness.
One alternative source is to phone around to Airstream dealers. A few have a pretty good parts inventory and can ship a bit faster than JC can. Out of Doors Mart in NC is where I got my set of bolts for the step. It would not surprise me if Colonial in NJ also has the parts ready for fast ship.
Old 08-27-2019, 04:28 AM   #7
Bbelk's Avatar
2010 27' FB Classic
This has happened to me three times. My fix is written up here:
http://www.airforums.com/forums/f366...ff-127219.html
The access hole made it possible to re-fix the problem on the road. I think I finally fixed it for good by adding some locktite to the bolt.
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
Bbelk is offline   Reply With Quote
Old 08-27-2019, 05:51 PM   #8
Woodway , Texas
Had the same thing (nearly) happen to us overnighting at Bennett Spring SP in MO. Released the step and the screw, a wavy washer and slotted nut fell out, fortunately, right below that side of the step. Didn't have an Allen wrench set with us (since added to tool kit) so used some blue Loctite and a small blade screwdriver to set things right until we got home. Un- and re-installed all of the little arm-attaching hardware with Loctite but still periodically check for looseness.
emelaich01 is offline   Reply With Quote
Old 09-18-2019, 09:00 AM   #9
Hi again. We are still on the road and the step you recommended is working well. The only issue is that the two steps are a bit concave which allow puddles to form when it is raining (not a big deal). I plan to replace the missing shoulder bolt after we return home later this week. Thx ...
Atlas Steps Stuck in the down position. RGJZ06 Airstream Motorhome Forums 9 08-11-2019 06:08 AM
How are your Septic Tanks Supported? bedfords Waste Systems, Tanks & Totes 4 09-23-2010 02:14 PM
How to properly set a trailer for extended time chasrahm Jacks, Stabilizers, Lifting and Leveling 9 07-06-2009 09:57 AM
Is there a list of supported browsers? guy99 Forum Admin, News and Member Account Info 22 06-19-2007 06:43 PM
Water Pump Not Working Properly? 74SovereignInt. Water Heaters, Filters & Pumps 8 11-11-2002 12:44 PM
