Old 11-03-2015, 10:39 AM   #1
1973 31' Excella 500
Santa Rosa Beach , Florida
Steps need bolts
I have a 1973 Excella 500 and it has a broken step. It needs two bolts to attach the arm to the top step so it can stay open in the "step" position.. instead of just hanging there.
I'm not sure which bold it is exactly, I just got it and I saw some on airstreamsupply.com, and wasn't sure which bolts I needed to get.
Anyone know exactly?
APevtPV is offline   Reply With Quote
Old 11-03-2015, 10:56 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy!
A call to the Mothership will get the specifics for you. In our 1999, they nailed it first try!
Good luck!
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-03-2015, 11:10 AM   #3
1973 23' Safari
1970 27' Overlander
Boerne , Texas
inland RV has all the step parts and bolts. Just fixed mine from parts from there.
Greg
Greg1410 is offline   Reply With Quote
Old 11-03-2015, 01:14 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Greg
That is where I got my parts, too. I used info from Airstream customer support to get the correct ones. Or I just got lucky.. Don't forget the washers, etc. and use Blue Loctite on the threads.
Channing
WBCCI# 30676
Old 11-03-2015, 02:32 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Airstream Double Step
Open the above link, then click on the blue spot on the part of the step that you need and you will be linked to that specific part
Alan
Old 11-03-2015, 02:36 PM   #6
CraigFulton's Avatar
1962 22' Safari
Saint Petersburg , Florida
Images: 53
Send a message via ICQ to CraigFulton
I would stay away from airstream supply if you can. Customer service isn't so great. Inland on the other hand has been a pleasure.
http://youtu.be/avRIpHurdCc
CraigFulton is offline   Reply With Quote
Old 11-03-2015, 02:46 PM   #7
2010 25' FB Flying Cloud
Davenport , Iowa
Be careful on ordering the parts. When I went to the local A$ dealer to order those parts, my wife was with me and she found a new A$. There is a BIG difference between $25 and $5k
Airtandem is offline   Reply With Quote
Step Support Bolts. . . JeffandSuzanne 1998 Excella 1000 16 08-05-2013 10:34 PM
Need Steps for our 1977 Argosy Minuet 6.0 Metre myboyburt Steps 2 07-31-2008 03:29 PM
Door hinge bolts/access hole ViewRVs Airstream Motorhome Forums 9 04-29-2003 08:44 AM
lug bolts Chas Axles 3 02-18-2003 09:55 PM
Loose exterior door hinge bolts JoeGillis Doors & Locks 2 10-21-2002 11:11 AM
