I got mine twisted when I accidently lowered the trailer on them while extended.
Get some spray greese. Lubricate any and all arms and connecting parts. May need a pry bar to get the stepa out. Do not pry on soft parts of trailer. Inspect after extended and look for a twist or bent parts. Aluminum is forgiving to a point try to straighten small twist.
I agree with Goin', but be light in your use...I loosened a tree stump with mine, and tried the 'hit it from the other direction' approach...at least I managed to remove the tree stump, but I had to grind out the swivel rivets, play blacksmith with the brackets, and replace the rivets with lots of washers and plastic-lock nuts and bolts...
The second time I re-aligned the steps, I knew what to do, and didn't have to use the grinder...just a couple of wrenches...hope I don't have another chapter to report...
Michael & Tracy
1989 345 Motorhome CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
Visit our blog http://www.scrapirony.com/ We live for the moment, 'cause when you get there, it's gone...
I sprayed penetrating oil on mine. I didnt think it could possibly help because they were so tight in place and now i can lower them and slide them back into place with one hand. A little oil goes along way..
Vin
Vin,
Have you considered a political future?
Yep, try the least invasive(smallest hammer) and work up...good advice.
Michael & Tracy
Vin,
Ok.. so the real me wears old jeans and putz's around in the backyard with the airstream.
The weekday Vin wears a tie and works as a Service Manager at a Mercedes Benz dealership. So yes.. I'm a cheerleader for 27 line technicians (mostly just adult daycare) and i have to be very careful with our cliental and what i say.. and how i say it.. even when i just want to boot them out the door!
SO!!!you ARE a politician...GOOD FOR YOU!!!...I'm a retired ER nurse with a box of latex gloves, and a tube of lubrication that does NOT generally win many friends...uhm...that I would particularly want around the house...oh, lordy, I feel like I'm drawin' the noose tight and standin' on the centered square in the floor...
Michael & Tracy
Not to worry...the key word is "retired"...the key worry is...why do I still have such stuff...?
Michael & Tracy
The steps are so hard to pull out and will not go all the way in the last 3 or 4 inches when I push them in. Help!!
Due to my carelessness, I had the misfortune of pulling our "new to us" AS just a week or so after we got it with the steps down.
It was parked near the curb outside our house and the steps did a great job of ripping up a few feet of turf!
I was pretty sick about it when I found the steps were then jammed and would no longer go up.
Looking closely I could see slight bending of some of the struts. i probably should have taken it apart to do a proper repair, but knowing aluminium is pretty malleable, decided to give the linkages a few gentle whacks with a small sledge hammer - of course using protective wooden blocks.
That, and a spray of silicon to all pivots seemed to rectify teh problem in short order - thankfully!
Hopefully I have learned from the experience as no doubt others have!
