Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 03-24-2003, 09:49 AM   #1
lmbando
lmbando's Avatar
Profile:
steps
Where can we purchase a double entry step for our AS?
John & Linda Bando
lmbando is offline   Reply With Quote
Old 03-24-2003, 04:59 PM   #2
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Linda,
I'm not sure if the '97 Safari is the same style as my '01 but if it is, Airstream does not offer a double step version. Check out this thread and you will find a post from a fellow from Ontario Canada who had his dealer change out his single to a Classic double step. Note that it took some metal cutting and welding. I inquired at Jackson Center and was told that they couldn't (or wouldn't) do it.
http://www.airforums.com/forum...=&threadid=326
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 03-24-2003, 07:31 PM   #3
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Step Picture
Is this what you folks are talking about? I took this picture at the factory in November. Guide told us it was a $900 option. It looks just like the one on my AS, but the bottom step is missing. It would be nice to have the bottom step, because I gained a couple inches in height, since the axle replacement.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 03-24-2003, 08:03 PM   #4
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Pick,
The bottom step can be added, but get the checkbook out!
If you can get one from a boneyard you will have more spare cash for the next repair/upgrade.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 03-24-2003, 09:15 PM   #5
femuse
Profile:
I did not realise we were sitting on a gold mine.
We do not have ONE but TWO of those, on our 1971 and 1974.
We rarely use them. When open all the way, it feels wobbly, there is too much flex.
So we solved the problem on the 71, which has been grounded 100% for 6 years anyway.
A bit bulky for traveling, and I guess it does not match the "Airstream Vintage look"
femuse is offline   Reply With Quote
Old 03-24-2003, 09:17 PM   #6
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
Pick,
I assume you took this picture of a Safari. Its good to know they are listening. I think that $900 is pretty excessive. Almost like they are trying to disuade you from adding this. This must be new for 2003 because it wasn't available when I checked in August 2001 when the 2002 models were being produced.
I don't believe that that stair as shown in your picture is a bolt on replacement. Probably why it costs so much.
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 03-25-2003, 11:49 AM   #7
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Footstep
Airstream's price on the "double footstep" is $730.35.
A long way from $900.00.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 03-25-2003, 11:53 AM   #8
femuse
Profile:
I take this was humor?
Old 03-25-2003, 12:53 PM   #9
Pick
Pick's Avatar
Images: 36
Once again....
Geez! We must of had a lousy tour guide. That guy appears to be a fountain of mis-information. The price of $900 is what the tour guide told us. Now, I am wondering if I can believe anything the guy said period.
Lots of Hot Sauce!
Air # 283
Old 03-25-2003, 01:30 PM   #10
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
$730 vs $900
May have included a couple of hours for installation....
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
InsideOut is online now   Reply With Quote
Old 03-25-2003, 02:38 PM   #11
74Argosy24MH
Profile:  LOST , Hawaii
I can't imagine a welding shop that wouldn't jump on it for $200, you have a picture for them to see and could get the drop you wanted.
If it doesn't have to be attached, how about this. I thought another forum member had one and was happy with it.
John
74Argosy24MH is offline   Reply With Quote
Old 03-25-2003, 03:28 PM   #12
jcanavera
jcanavera's Avatar
Fenton , Missouri
Images: 143
Here's what I'm using and it easily fits folded in the rear Safari storage compartment.
http://www.campingworld.com/browse/s...3&skunum=13291
Jack
Jack Canavera
STL Mo.
AIR #56
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 03-25-2003, 04:06 PM   #13
JaceBeck
Profile:
I checked on the double aluminum step as well. I spoke extensively with A/S and the step manufacturer.
It can't be easily done on a late model Safari and, by the time you are done, with labor rates between $60 and $80/ hour at an A/S dealer, it is close to $1K, give or take a few bucks. I took a pass.
Jace
P.S. In the process, I found the manufacturer of the steel Safari steps and asked them about thier two-step steel steps that they make for other RV firms. They do not easily fit either as a replacement.
1999 Safari 25C
2001 Yukon SLT
WBCCI #2369
JaceBeck is offline   Reply With Quote
Old 03-25-2003, 05:22 PM   #14
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Separate step
Both of the free-standing steps noted above would work great. I used a separate step of this general type on my old Scamp 5th-wheel which had no built-in step.
One thing to think about is that the further the steps protrude from the trailer, the more the leverage there is and the more trailer shake you are going to get whenever someone heavy enters. A separate step does away with that problem.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Cutter water leak at steps Pam Airstream Motorhome Forums 0 09-02-2003 01:17 PM
Excella steps? Warren W. Wiley Steps 7 08-21-2003 10:28 PM
T/T Electric steps anyone? Excella3287 Steps 0 03-05-2003 01:27 PM
Steps Texas Steps 6 10-31-2002 11:50 PM
