Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 10-27-2002, 11:03 AM   #1
Texas
Profile:
Steps
I just bought a 1975 Sovereign. I can not figure out how to get the steps beneth the door to go down. Can anyone help me with this?
Texas is offline   Reply With Quote
Old 10-27-2002, 03:45 PM   #2
Craig
Profile:
Not sure if it is the same as my 78, but all you should need to do is press down on either side of the latch bar. The step is meant to automatically come down, but I need to wiggle mine around a little bit to get it fully extended.
Craig
Craig is offline   Reply With Quote
Old 10-27-2002, 03:47 PM   #3
paul k
Profile:
steps
hi tex
on my 76 there is a small lever on the lower right side of the door all you have to do is push the lever down and the steps should drop down then you pull it out the rest of the way it sounds like yours may be jamed try tapping it with a rubber mallet to loosin it up good luck
paul k is offline   Reply With Quote
Old 10-27-2002, 03:50 PM   #4
Kistler
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
Step
We just bought a 2002 Classic and have a step problem; it is worse than a rubric cube.
Ours is a 2-step, folding before latching. I wish that they would have published a booklet on how to unfold and fold the step.
Kistler
Kistler is offline   Reply With Quote
Old 10-27-2002, 04:04 PM   #5
Texas
Profile:
Step
Craig and Paul
Where exactly is the lever or latch standing outside facing the inside, left or right, in the floor just inside the door, inside up on the wall, or outside to the right or left of the step as one is facing inside the trailer.
Thanks, Texas
Old 10-27-2002, 05:13 PM   #6
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Standing on the ground looking at the step is there a horizontial bar that is just above the steps? If so there should be two ears, left and right. Lift up on the ears and the step should slide right out. DO NOT STAND TOO CLOSE, or the step will whack you so hard in the shins you will say bad words!
If when they open you are looking at the bottom of a step ( alumimum not a black no slip surface) then you have a double step as was mentioned above. Opening the double step is easy. Grab the back edge and lift it up, flipping the step into the open position and it should hang from the front edge of the top step.
To Close the bottom step, lift the front edge of the step and if I remember flip it back to where it started, you may have to wiggle some stuff but it should all lay flat like you found it. Once you figure it out it is easy.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 10-31-2002, 10:50 PM   #7
Joan D'Andrea
Joan D'Andrea's Avatar
Profile:
Hi Brett. I have a '78 Sovereign. The steps are a bit tricky. The advise here is good. In addition to what you have read so far I suggest you watch which way the folding bars go, they should go back and not forward. If they go forward the steps will jam and will not level properly. Mine have no little bar that makes them go the correct way. It is just a matter of leaning over and pulling out. I hope your steps are level. Mine must have had a pretty substantial person really hoppin' on them as the bottom one is permanently dippy. A block of wood under the bottom step helps, but it has to be very carefully measured. We put a block that was a bit too big under ours the first time and took a flying leap. JLD
Kalakkala II
Joan D'Andrea is offline   Reply With Quote
Demystifying the engineer, 9 steps. thenewkid64 Off Topic Forum 2 01-14-2004 08:33 AM
Cutter water leak at steps Pam Airstream Motorhome Forums 0 09-02-2003 12:17 PM
Excella steps? Warren W. Wiley Steps 7 08-21-2003 09:28 PM
T/T Electric steps anyone? Excella3287 Steps 0 03-05-2003 12:27 PM
