Old 11-23-2011, 09:19 PM   #1
PINOLE , California
Step strut
On the drop down front step it looks like a thin wide bolt and nut that sits flush in the counter sunk portion of the strut. One side has an allen head screw. I have one of those that has sheared off. The nearest dealer to me just closed. Does anyone know the part number on that and/or where it could be ordered from. Hope this gets through ok and I can receive any replies as my computer skills are about on the same level as my repair work skills. Thanks for any help I can get.
Jerry Webb
jwebb90162 is offline   Reply With Quote
Old 11-23-2011, 10:21 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
out of doors mart has stair parts.
http://odmrv.com/catalog/index.php?m...e1b6aed59f6257
Chris
Old 11-23-2011, 10:24 PM   #3
Jerry Webb
There are many descriptions of the step hardware, that is very confusing.
It's better if you pick out the parts or parts you need from an exploded view drawing, that some dealers can send to you.
Old 11-23-2011, 11:37 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I got one of those last spring from Andy at Inland RV.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 12-12-2011, 01:34 PM   #5
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Repairing double step
We just brought home our 2004 25' Airstream Classic, and the double step will not engage correctly in the front outrigger, causing it to sag under weight. Looks like to repair or look at the bolt that holds the step bracket, a person would have to remove a cover (sorry I'm new and haven't learned the correct descriptions yet) to access to bolt that goes thru the slider slot and the outrigger itself. Am I missing something or is this the only way to repair the double step? I would like to get this repaired as soon as possible, to avoid further damage. It appears that the step had probably been left down had struck something as there is a slight bend in the front step bracket.
Thanks in advance,
Rod
rbs is offline   Reply With Quote
Old 12-13-2011, 12:29 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Check my post on 6/11/11. If you have the same problem this should resolve it. It sounds like the notch at the end of the curved slot is worn. With some careful filing it can be made to work again. I had posted some photos to help resolve the problem, but I'm on my iPod now and the pics don't show up. You may have to go up or down on the thread to find the pics.
TG Twinkie is online now   Reply With Quote
Old 12-13-2011, 12:50 PM   #7
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
There's a good thread about steps here: http://www.airforums.com/forums/f475...put-37081.html
Vaughan
Old 12-14-2011, 03:37 AM   #8
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Alright
Thanks so much, as I am certain that is the problem. I will get my Dremel out and report back.
Rod
Aluminum Step Parts perryg114 Steps 2 10-05-2011 07:26 AM
2nd step goshawks00 Steps 6 09-09-2011 09:25 PM
Carpeting 1967 step top? Stella Steps 2 07-04-2011 06:18 AM
Electric sliding step warning buzzer hc24 General Repair Forum 1 05-09-2011 07:45 PM
Argosy entrance step argosyman Steps 4 04-28-2011 08:52 AM
