Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 05-31-2009, 09:58 AM   #1
Profile:  1973 Argosy 22
Odessa , Florida
Step slide rusted out
Hello all, I have a problem with my 73 Argosy's step. The slotted part that the step slides in is rusted out. If you check this thread. Step repair and look at post #5 you will see a similar problem (mine's the forward rail) and the piece I need to repair it (the forward version). So far so good but .... I can't find that part online. Probably because I don't know what it is called. It is a 22' Argosy if that makes a difference. Thanks much for any help you can give. Don
Odessa-Don is offline   Reply With Quote
Old 05-31-2009, 11:36 AM   #2
lynn's Avatar
Profile:
What you need is the step outrigger which can be ordered from an Airstream Dealer.
lynn is offline   Reply With Quote
Old 05-31-2009, 12:35 PM   #3
Commercial Vendor
Profile:  Corona , California
You need both step "outriggers" so that you have a matched set.
Rusted out or worn out step outriggers, is rather common.
The only problem is that they have to be welded in place, very carefully, so that both sides are exactly the same.
A very few dealers stock them.
They are not expensive.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 05-31-2009, 03:46 PM   #4
Odessa , Florida
Thank you both for the quick responses. I will order a pair. Don
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 767 10-20-2009 10:53 AM
Step by Step Repair for 1965 Caravel jlovelady Steps 1 04-17-2008 10:18 AM
Rusted Rivets luckydc 1999 - 2004 Bambi 6 04-01-2005 11:16 AM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 27 11-23-2004 07:01 PM
Rusted through hardware on step - source? caadoptees Steps 7 07-01-2002 11:48 AM
