Old 03-02-2016, 04:34 PM   #15
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
different how.. wider, longer, 3 steps etc.. the 2005 classic 31 we are buying has a broken bottom of two steps and was looking at the camping world replacement steps. they seem to be a bit more able to handle the stress of everyday usage.
Originally Posted by BoldAdventure View Post
They're all the same except for the Classic's which had different steps.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 03-02-2016, 05:13 PM   #16
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Just quoting something I read earlier. And observation. But the mounting holes are most likely all the same. Probably industry standard.
Originally Posted by idroba View Post
This is a copy from a Forum post in the past few months. I kept it in my file, sorry I can't give proper credit to the original author.
"I had to replace the steps on 25' Flying Cloud.
Did some research and the replacement steps were purchased from Campers World for $81 plus $10 shipping. Campers World part number is 74960.
The manufacturer is Lippert Components and their part number is 341500.
This step is exactly the same as OEM steps from Air Stream. Bolt holes match and installation took 15 minutes. Remove 4 bolts and the steps come off."
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-02-2016, 09:14 PM   #17
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Suggest calling the factory to verify the mountings for the Classic weird folding aluminum step would also work with the standard steel step. Might save some shipping expense.
Old 03-03-2016, 07:30 AM   #18
2015 28' Flying Cloud
Melbourne Beach , Florida
Step Replacement
My original post which detailed replacement steps should have included that the 25' Flying Cloud was a 2013 model. I had damaged the steps and bent them.
Was not easy to identify replacement steps as there are no dimensions or templates on the various websites. I removed the steps, 4 bolts and around 4 minutes labor, and was able to get accurate dimensions. I found replacement steps readily available and i ordered online at Camping World. Reattached steps using same bolts I removed.
If you go to a dealer it will cost you $300-400 to replace steps. Do it yourself for under $90.
Kingsmen 33 is offline   Reply With Quote
Old 03-03-2016, 08:27 AM   #19
1999 28' Excella
New Orleans , Louisiana
We put on steel steps because of full-timing. Our steel steps were put on by an AS dealer the aluminum steps were wider. They added stainless steel bands to decrease the width. They work great. Glad someone suggested steel.
badkat is offline   Reply With Quote
Old 03-04-2016, 06:38 AM   #20
carl2591's Avatar
2005 31' Classic
good info.. when you say SS bands to decrease width you mean they put a "shim" in on both sides to make up the difference between steel steps width and mounting area on airstream width.. almost like putting a washer in there..
how thick would you say the SS bar is.. any pictures you can share.
Carl, Raleigh NC
Old 03-24-2016, 10:36 PM   #21
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Does anyone know here if the Pendleton model aluminum steps fit or bolt up to any Flying cloud?
subfan1 is offline   Reply With Quote
Old 03-25-2016, 04:21 AM   #22
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
The Pendleton model is just a variant on the Classic - which used to be called an Excella in the 80's. If you go up a few posts an Excella owner traded his floppy aluminum steps for the steel ones and those had to be shimmed because the aluminum ones were wider.
Whether you could shim them the other way? You could call the factory and ask. Or perhaps if you go to a rally or Airstream park you could get permission to crawl under someone's classic and see how the steps are attached.
I've never thought of it before - but I am pretty certain the doors are the same width between a classic and any of the lower trim models. I have a "Home Sweet Home" grill on my screen door - and have seen the same thing on a friend's Classic. So the raw opening should be the same.
BTW those aluminum folders look cool, but they are "costalotta" items AND they have issues. They sag - and there's one very expensive (like $100) screw that is custom made, possibly with reversed threads that tends to work itself loose and fall out. Several people have made special braces to hold them steadier. And many classic owners, especially if they have balance issues either convert to the steel steps or use a freestanding stool just so they can keep on 'streaming. I am currently camped next to a man who has to use a walker and he and his wife just got an aluminum ramp for their moho to make life easier for him.
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
'65 Caravel dump valve replacement step by step kevinkatz Waste Systems, Tanks & Totes 8 01-08-2015 08:45 PM
Step by step shell on, front floor replacement '69 Safari thesignlady Repairing/Replacing Floor &/or Frame 31 11-03-2014 11:24 AM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 07:49 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
