Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 04-13-2009, 12:20 PM   #1
Profile:  1979 25' Tradewind
Lebanon , Tennessee
step repair
I have been trying to get the bolts out of the steps to replace the two bolts that locks the steps in place. I tried heat, oils and still no luck these are the allen bolts on the sides of the steps I don't wont to strip or break them got any ideals how to loosen them.
m garrison is offline   Reply With Quote
Old 04-13-2009, 01:18 PM   #2
SaabLover's Avatar
Profile:  1974 31' Sovereign
Almost Always Sunny Sarasota , Florida
Images: 12
Soak it with PB Blaster over night (better then WD 40). If that doesn't work you just may have to drill it out. If you drill it be careful not to drill into the bushing I don't know where to get those.
You can get PB at Homies, Lowes or almost any good hardware store. By the way I was able to get those bolts at Ace Hardware Store. In stainless steel.
1999 Chevy Suburban 7.4LT "Tugger" Last of the big boys! Still going strong. 1992 Saab 900s Convertible 60K miles Not my TV
Almost always sunny here unless there is a hurricane bearing down on you. And then it's time to hook up the burb and roll. So far I've been very lucky.
SaabLover is offline   Reply With Quote
Old 04-13-2009, 01:41 PM   #3
arodriguez60's Avatar
Profile:  1973 23' Safari
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 44
If byou damage the bolts out of doors mart carries the bolts and bushings. When I did mine I made the partd myself on a lathe and bridgeport mill. I wish I would have known that ODMRV had them.
arodriguez60 is online now   Reply With Quote
Old 04-13-2009, 04:59 PM   #4
Lebanon , Tennessee
Thanks going to lowes in a few to try pb blaster. I had soaked it in penetrating oil may not have waited long enough, Thanks again
Old 04-13-2009, 05:21 PM   #5
DEITZ645's Avatar
Profile:  2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 99
Airstream Registry
M Garrison,
I "reconditioned" my steps as a little winter project and I too had a "fun" time getting the steps apart. My pleasure was doubled because our '87 has two doors. I was going to just replace the whole step assembly until I saw how much they cost. So I decided to replace the anti-skid stickers and all the worn or corroded bolts. I was fortunate enough to find them on Out Of Doors Mart's web site. After I got the steps apart it went fairly easy. You can read about it and see some of the bolts I had to remove and how I removed them here...
Reconditioning Folding Steps
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package Katarina
1987 34' Excella 1000 Double Door Savannah
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
AIR #14487
WBCCI #7429
DEITZ645 is offline   Reply With Quote
Step by Step Repair for 1965 Caravel jlovelady Steps 2 12-19-2009 02:23 PM
Step repair housebg Steps 5 06-05-2008 07:33 AM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 27 11-23-2004 06:01 PM
step repair smallfry Steps 2 07-22-2003 12:57 PM
Step repair trumpwer Steps 1 03-03-2003 09:44 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
