Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 06-04-2008, 10:26 PM   #1
housebg
Profile:  1983 27' Excella
French Settlement , Louisiana
Step repair
Well I found a rotten spot in my floor . At the door so I though might as well fix the steps while I am at it. Here is the first pictures. Many more to follow Billy
Name:	airstream parts 001.jpg
ID:	61784   Click image for larger version
Name:	airstream parts 002.jpg
Name:	airstream parts 003.jpg
housebg is offline   Reply With Quote
Old 06-04-2008, 10:39 PM   #2
DPeakMD
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
That seems to be a very common area for floor rot. We had it there in our Excela, too. Good luck with your repair!
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-04-2008, 10:46 PM   #3
housebg
With floor removed
Well this is without the plywood and metal sheet under it Billy
ID:	61787   Click image for larger version
Old 06-04-2008, 11:49 PM   #4
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Rotted flooring at the entrance door area is caused by a bad door gasket and/or a warped door frame.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 06-05-2008, 07:05 AM   #5
housebg
Getting to the bad
This is what I have needed to fix for a while, it went bad soon after I got the trailer. The second picture is the new rail, Billy
ID:	61796   Click image for larger version
Old 06-05-2008, 08:33 AM   #6
DPeakMD
DPeakMD's Avatar
Franklin , Indiana
Make sure you coat all the exposed metal with a good rust proofing paint (e.g., POR-15). Better check out the wheel wells. They're prone to rusting out, too.
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
Step by Step Repair for 1965 Caravel jlovelady Steps 1 04-17-2008 10:18 AM
drop down entrance step repair jasper2222 Steps 16 05-31-2005 12:24 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 27 11-23-2004 07:01 PM
step repair smallfry Steps 2 07-22-2003 01:57 PM
Step repair trumpwer Steps 1 03-03-2003 10:44 PM
