Old 02-08-2016, 09:43 AM   #1
1989 34' Excella
Step Light: '89 Excella
My '89 Excella came with a broken/missing housing for the little light by the steps. It had a little unidentifiable bulb in it. See photos.
The closest I've been able to find is this one:
http://odmrv.com/catalog/index.php?m...roducts_id=746
But it looks a little more rectangular. I suppose I could just drill new holes, but wondering if anyone has ideas for a more direct replacement or alternate approach. Thanks!
ID:	257020   Click image for larger version
MohawkDaddy is offline   Reply With Quote
Old 02-09-2016, 09:05 AM   #2
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
perhaps this one?
http://odmrv.com/catalog/index.php?m...roducts_id=295
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 02-09-2016, 10:26 AM   #3
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
1156 bulb?
Cyquest is offline   Reply With Quote
Old 02-09-2016, 11:27 AM   #4
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
iirc, 1141. 1156 more likely to melt the lens...
16 watts (1141) vs. 27 watts (1156)
Joseph & Gabrielle
Old 02-09-2016, 05:06 PM   #5
1989 34' Excella
Thanks, JM2 - I've asked OODM what the dimensions are and what sort of bulb it uses. Will post what I learn.
The first option I linked to is quite a bit larger and mounts vertically. I'd certainly have to cut a bigger hole to install it, which I'd like to avoid.
Old 02-10-2016, 06:59 AM   #6
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
your first option has a lens that actually helps point the light downward, sort of like a headlight. the 2nd one is just protection and diffusion for the bulb, no real optics there.
Joseph & Gabrielle
Old 02-10-2016, 03:15 PM   #7
1996 25' Excella
Tillsonburg , Ontario
I had a similar issue with my '89 Excella. The light fixture at the dump valves was busted. I believe the bulb is non-standard compared to the rest of the lighting in the trailer since I needed to change the bulb at the steps also and had to go looking at RV supply stores. I replaced the complete fixture at the Dump valves. Drill out the rivets. Install new one with rivets or SS screws. Probably should add some caulking
JCW
JCWDCW is offline   Reply With Quote
Old 02-10-2016, 05:21 PM   #8
You can replace the entire fixture for less than $10.00
0557 is offline   Reply With Quote
Old 05-10-2016, 06:43 PM   #9
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Does anyone know where the switch is for these lights? Or do they trigger automatically somehow?
John
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 05-10-2016, 06:53 PM   #10
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
You can find a direct replacement led assembly at most truck stops. Its like $9
The bulb in yours is a 3 watt bayonet bull. It simply pushes in.
Old 05-13-2016, 02:33 PM   #11
1989 34' Excella
Huh ... I just looked for the switch that controls the little light by the stairs, and was unable to find it.
The switches by my door are labeled 'STEP' (which lights the outside lamp over the exterior door) and 'FLOOD' (which I believe lights the lamp above the bay window on the side with the exterior door, though mine isn't functioning right now).
I turned both switches on and probed the stairstep light wires with my voltage tester, and didn't get a signal.
I haven't gotten around to replacing this fixture yet, but it'll be hard to do so if I can't get juice running to it!
Can someone with a working stairstep light in an late-80s Excella let us know definitively where the switch is?
Thanks --
Old 05-13-2016, 02:51 PM   #12
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
My '85 Sovereign step switch operates the over the door light and the light you speak of at the right of the steps in the under belly pan under the rub rail molding.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 05-14-2016, 06:26 AM   #13
1989 34' Excella
Thanks! Must have a wiring problem with mine. Will troubleshoot further ...
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 07:49 PM
Step-by-step sewing an awning yukionna Awnings 11 12-28-2006 01:37 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
