Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 04-17-2008, 09:33 AM   #1
'65 Caravel 17'
jlovelady's Avatar
Profile:  2001 34' Limited
1965 17' Caravel
Lufkin , Texas
Step by Step Repair for 1965 Caravel
I read several posts regarding step repair just prior to damaging the steps on my 1965 Caravel. The step caught a gate post and was bent back at at 20 degrees. Here is how I repaired the steps.
1. I cut the long bolt underneath the step (Caravels have one step) one inch from the left end.
2. Removed the step toward the left after prying out the stud bolts from the sliding grooving.
3. Placed the bent arms in a vice and used a pipe wrench and two large cresent wrenches to slowly straighten the arms to original positions.
(Note: Banging with a hammer will damage the material and cause fractures and not accomplish much.)
4. Used a framing square to align the arms with the sides of the step.
5. Inserted the step on the long rod and pried the arms stud bolts back into the grooves.
6. Welded the rod underneath the step end to end.
7. Made a few alignment adjustments, repainted, and it works fine.
Note: The two main hanging support arms were bent and had to be straightened the same way as the grooved arms.
Good luck on yours.
jlovelady is offline   Reply With Quote
Old 04-17-2008, 10:18 AM   #2
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 42
Great job
I will put this in my Caravel book.
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 767 10-20-2009 10:53 AM
Need a step for '65 Caravel amron Steps 3 02-14-2007 06:57 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 27 11-23-2004 07:01 PM
step repair smallfry Steps 2 07-22-2003 01:57 PM
Step repair trumpwer Steps 1 03-03-2003 10:44 PM
