Old 06-12-2016, 04:07 PM   #1
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Step bolt replacement
Wondering if anyone can tell me where to buy a replacement bolt for our step ('79 Excella).
Here's a picture of the one that's missing/broken:
Name:	ImageUploadedByAirstream Forums1465769165.937431.jpg
And he's a picture of the same hinge on the other side of the step:
Name:	ImageUploadedByAirstream Forums1465769194.288290.jpg
Any advice?
- Jay & Jetty
trekerboy is offline   Reply With Quote
Old 06-12-2016, 04:12 PM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Attachment 264360
Attachment 264361
Any advice?
- Jay & Jetty
http://odmrv.net/AsDouble%20Step.php
martin300662 is offline   Reply With Quote
Old 06-12-2016, 08:49 PM   #3
Mixter's Avatar
1976 27' Overlander
Let me know how you get that bolt out..... mine look in MUCH better shape than that, and I couldnt get them out for nuthin.... Soaked in PB Blaster for days..... Was going to rebuild with all new just because I had the chance while everything was all apart.... but I finally gave up and just reinstalled, and praying I dont need to rebuild later.
Mixter is offline   Reply With Quote
Old 06-13-2016, 05:42 AM   #4
trekerboy's Avatar
Originally Posted by martin300662 View Post
That's it! Thanks so much!
Old 04-30-2018, 10:18 PM   #5
Amesville , Ohio
Has anyone ever heard whether loctite is used on the flathead Allen bolts that secure the top step to the hanger side bracket? I saw that PB Blaster was tried. Has anyone tried light heat and Kroil. The reason for the attempted top step disassembly is because the upper rear bolt pins have begun to back out. This makes sliding the step in and out quite difficult. It is my hope that once the step is removed from one of the hanger brackets, that the bracket can be rotated inward, lifting the pin from the larger portion of the curbside end of slide channel. Thank you ODMRV for the pic link.
toothpick is offline   Reply With Quote
'65 Caravel dump valve replacement step by step kevinkatz Waste Systems, Tanks & Totes 8 01-08-2015 08:45 PM
Step by step shell on, front floor replacement '69 Safari thesignlady Repairing/Replacing Floor &/or Frame 31 11-03-2014 11:24 AM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 07:49 PM
Bolt for step needed.... kooshka Steps 12 06-05-2008 01:02 PM
Step problem--bolt fell out--inaccessible Kistler Steps 4 08-24-2003 12:07 PM
