Old 04-20-2011, 03:12 PM   #1
TinLoaf's Avatar
2006 25' Safari SS SE
Trenton , Illinois
Images: 22
Safari Step Replacement Photo Guide
The pivot bar on our folding steps supports a substantial amount of weight and it sheered off on the right side causing my steps to sag and flex.
You can get new steps shipped to your door for about $130 and they're a simple replacement. I chose the newer "radius" model with the curve to the steps as seen on the 2009 and up Flying Clouds and Internationals.
Removal of the old steps is as simple as removing the four 9/16 inch bolts.
Here you can see the old compared to the new.
Removing the steps alerted me to the fact that the outriggers on my frame are already rusting. I'm not very happy about that.
I used the original bolts to reattach the steps because they were longer than the ones included with the new steps. The holes line up perfectly and you don't need any of the extra parts that shipped with the new steps. It's a 15 minute job.
The curve in the radius steps makes a huge difference in the amount of space you have to place your foot when stepping out of the Airstream. I couldn't believe the difference. I wish I had taken before-after photos looking down from the door.
The new steps stick out just a tiny bit more than the old ones when folded. Another difference is that they're black instead of gray. Other than that, it's an easy job to tackle if your steps break or you want to upgrade to the newer radius steps. I'm very pleased with the results. I hope this guide helps.
Steve
TinLoaf is offline   Reply With Quote
Old 04-20-2011, 03:33 PM   #2
Forger's Avatar
2011 25' FB Flying Cloud
Columbus , Indiana
That's a pretty good looking helper you have there!
Bill & Martha
2011 25 Flying Cloud #525456
2010 F150 Lariat SCAB, 5.4L, 3.55:1
Forger is offline   Reply With Quote
Old 04-20-2011, 04:34 PM   #3
elfirebob's Avatar
2007 25' International CCD FB
1970 23' Safari
1956 16' Bubble
Jamul , California
Images: 159
Simple, easy and a great guide...thanks!
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
2007 25' International FB
1970 Safari 23' Land Yacht
1956 Bubble 16' California Whale Tail
Charter Member 4 Corners Unit
(View all of elfirebob's images)
elfirebob is offline   Reply With Quote
Old 04-20-2011, 05:10 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We had the very same problem with Lucy's steps a couple of months ago.
We got a set of the curved steps also, We like them so much better than Lucy's original steps. They work better and they look better.
We found ours at Camping World for $70.00 plus tax delivered to the Tallahassee store.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
moosetags is online now   Reply With Quote
Old 06-12-2011, 05:46 PM   #5
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
Whew, a solution!
Thanks to both Tinloaf and Moosetags:
I've been getting irked by my steps as they need paint and also there is a weird dent in what I believe to be the banana wrap just aft of the steps, as though someone backed into something while steps extended. I guess they just bent the steps back somehow but it does'ent look obvious.
Yup looks like a simple job.
I gotta get me a set of the new radius ones .... I'll try Camping world as I joined them right after getting Tinbad.
Thanks!
Del Gurney is offline   Reply With Quote
Old 09-09-2011, 06:17 AM   #6
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
We really like the looks of this step..unfortunately they are 24" wide , so they will not fit our 66 Safari , which is only 20" wide... BAH!! So we will continue to look for a set of steps for easier access....
Barry & Karen in Mi.
goshawks00 is offline   Reply With Quote
Old 07-18-2015, 09:02 AM   #7
JJ1
2009 23' International
Redondo Beach , California
I needed to replace the double steps on our '08 International. The prior owner had tried to drive away with them down and bent the steps. He had them repaired but they always drooped down on one side when you stepped on them.
I read your post and ordered the same step, but when they arrived I noticed that the steps have a punched slot pattern, unlike the original smooth steel step on the old and like yours; not as comfortable on bare feet! I ordered the same Carlson Stromberg Hickory Step, but I was surprised because the image of the steps from the retailer looked exactly like yours not the slotted type I received. I noticed some of these slotted type on some of the new AS's at the dealer and didn't know if they changed the design. Was wondering if you can still get the smooth type of step?
John
JJ1 is offline   Reply With Quote
Old 07-18-2015, 10:15 AM   #8
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Like those new curved steps. Mine has the narrow straight one. I have to step out almost sideways to feel safely balanced. Mine are still in good shape but if they ever crap out will have to remember this thread.
MICHAEL
folding, radius, safari, step, replace
Carpeting 1967 step top? Stella Steps 2 07-04-2011 06:18 AM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
January 2011 Photo Contest InsideOut Photography 93 02-02-2011 03:01 PM
Windows Live Photo Gallery JBinKC Photography 7 01-13-2011 07:06 PM
