Old 11-19-2014, 11:22 PM   #1
triterra's Avatar
1969 27' Overlander
1976 Argosy 28
Lodi , California
Repair of sloppy step and addition of second step 1969
Our step on our 1969 has been sloppy for years. It would not stay in place at the end of the groove. The slot metal was worn and bending in and eventually cracked. Finally had a mobile welder come fix it. It is not the prettiest but way better! It does not move at all when you stand on it! Wish we did this 5 years ago! He welded the crack first then welded a small piece with a wedge/notch at the terminal spot when the step is down.
Before . Click image for larger version
Name:	ImageUploadedByAirstream Forums1416463935.871232.jpg
ID:	227010Click image for larger version
Name:	ImageUploadedByAirstream Forums1416464078.619229.jpg
AfterClick image for larger version
Name:	ImageUploadedByAirstream Forums1416464043.523000.jpg
ID:	227011Click image for larger version
Name:	ImageUploadedByAirstream Forums1416464112.693423.jpg
ID:	227013Click image for larger version
Name:	ImageUploadedByAirstream Forums1416464164.677961.jpg
I also had come across a second step that was too wide for ours. So I had it cut down and welded to fit ours. It is removable and folds flat for storage. We definitely needed it after replacing the axles!Click image for larger version
Name:	ImageUploadedByAirstream Forums1416464406.785089.jpg
Name:	ImageUploadedByAirstream Forums1416464464.811129.jpg
ID:	227016Click image for larger version
Name:	ImageUploadedByAirstream Forums1416464503.865506.jpg
Michelle
triterra is offline   Reply With Quote
Old 02-15-2015, 12:01 PM   #2
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Thanks for sharing this. I have to look at my step soon. Hopefully it will be this simple on mine :-)
thesignlady is offline   Reply With Quote
Old 02-15-2015, 06:23 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
And the step on my 66 has the same wear. It clunks when ever someone steps on it. I need the same type of repair. Thank you for sharing your repair method.
David
Old 02-16-2015, 12:00 PM   #4
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
All you need now is a hanger.
Cyquest is offline   Reply With Quote
Old 02-16-2015, 12:30 PM   #5
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Mine has a longitudinal crack running along about half the angle iron at the edge of the step. Trying to get a buddy to come weld it for me. Anyone know if the whole step can be removed for easier repair?
BambiTex is offline   Reply With Quote
Old 02-16-2015, 01:40 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If the step is like the one on my '74. There are shoulder bolts thru the side of the linkage arms on each end of the step. They require either a 3/16" or 1/4" Allen wrench to remove the bolt.
TG Twinkie is online now   Reply With Quote
Hinge is sloppy MacDad Doors & Locks 5 06-22-2014 08:34 PM
Argosy MH double entry step addition bkahler Argosy Motorhomes 13 11-23-2012 05:15 PM
Sloppy step slots? blickcd Steps 2 05-29-2009 11:23 AM
Sloppy Steering... Auretrvr Classic Motorhomes 46 11-12-2006 01:23 PM
