Old 03-17-2013, 08:02 PM   #1
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Repair, don't replace steps
Our double steps broke on 2005 25' International. The 3/8" X 26" pivot rod sheared off, eliminating support on one side. One day our steps just felt flimsy and looked kinda drunk. You can see in this picture how crooked they are.
We decided we didn't want to add a bunch of steel to the junkyard somewhere, so we committed to trying to repair this. Turned out easier than we expected. the failure was the sheared pivot rod here, it is supposed to go through that hole but is now too short and the step kinda flops around when we step on it.
We bought a 3' piece of 3/8" steel rod. Sawed out the old pivot rod, ground off the welds, cleaned up the holes and slipped new rod through. Decided to pin the new rod from the inside of each flat washer. The rod is free to rotate and might wear more evenly than when it was tack-welded into wearing on one face only.
Steps are level, no longer are flimsy. Cost was $5 for the rod. Used a pair of 4d finish nails for pins, had the flat washers already. Re-used our original steps instead of junking them. (and yeah, I'll be painting down there soon) Successful repair!
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 03-17-2013, 08:14 PM   #2
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
Great repair job. Will keep this idea in mind if ours breaks.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
