Old 10-31-2011, 12:03 PM   #1
1981 31' Excella II
New Market , Alabama
Removing the steps?
So how do you remove the steps? Mine need a little R&R and I was wondering how you remove them. All of the bolts that attach the steps rotate and you can't get to the back side of them.
Perry
Old 10-31-2011, 12:16 PM   #2
Perry
Perry.
Service manuals are available for 1980 and 1982 trailers.
It answers tons of questions, in detail.
Old 10-31-2011, 05:00 PM   #3
1981 31' Excella II
Well I have a 77 service manual. I have not found it to be extremely detailed.
Perry
Old 10-31-2011, 05:50 PM   #4
Perry
They got better in time.
Airstream did not write those manuals.
A publishing company wrote them.
The 77 book has the same exact footstep as you have in you later trailer.
Exactly the same.
Old 11-01-2011, 09:19 PM   #5
Don McKelvay
Don McKelvay's Avatar
1994 34' Limited
London , Ontario
Hi Perry,
Twice I have broken a support arm (different arms) on our 1994 34 footer and had the same problem - how to get the bolt out. I am not sure if our rig is the same as yours but think they are pretty close.
I bent back the banana skin next to the step (see the picture) making a large enough entry to get a box wrench in and on the nut which is behind the skin. Then I used a hex wrench on the easily accessible bolt on the inside of the step. To ensure I did not lose the nut when the bolt came out I put some duct tape on the back of the box wrench when the bolt was almost out and the gently pulled the wrench and nut out. I could have rebent the skin but as it really does not show much just left it.
Same procedure putting it back together again. Hope this helps.
Cheers,
Don
________________
Don McKelvay
WBCCI #205
AIR #42
1994 34' Limited
2004 GMC 2500 HD
Hensley Hitch
Don McKelvay is offline   Reply With Quote
Kwik-Eze steps robber2711 Land Yacht/Legacy Motorhomes 10 01-11-2012 03:18 PM
'78 Tradwind Steps twilight10 Steps 7 09-19-2011 05:00 PM
Removing window frames '61 GT streamahead Windows, Doors, Locks & Vents 3 07-30-2011 09:47 AM
Yep, it's THOSE steps Jim & Susan Steps 22 06-18-2011 07:33 PM
'64 safari steps repair question Homewrecker Steps 4 03-14-2011 03:01 AM
